Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 09-01-2018, 04:41   #1 (permalink)
Member: 1484663
Thanks Meter: 344
Exclamation Help with G930T
Hi, I have a G930T with wiped EFS with another tool. This tool did not make a backup of EFS or any other, so this set IMEI it's 000000000000000.
Any way to get this S7 from T-Mobile repaired with Chimera?
Old 09-01-2018, 22:22   #2 (permalink)
Member: 2592628
Thanks Meter: 212
no
chimera can't help you with that.
Old 09-02-2018, 00:06   #3 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
When the Imei is in 35000000 that means that the EFS folder is corrupted and the security of the phone is damaged.
If either SW version is unknown, or HW Chip is unknown, or HW Modem is unknown - most likely phone's firmware firmware or
EFS is damaged, or you have written unsuitable firmware. Also, this can be HW problem.
You should re-flash the device with different firmware one by one and check, if modem is correct (not Unknown).
If after writing of all firmwares, which you have, problem remains the same - most likely,
this is HW problem (problem with eMMC flash chip).
Steps to try to rebuild the EFS folder with a combination file:
1. The first thing is to have our phone with imei in 0000-0000 or Unknown
2. Root, with CFAutoRoot and is done using Odin v.3.12.5 in the AP option and activate in addition to USB Debugging
Unlocking OEM
3. Once the root is done we proceed to install a Root Explorer and access the EFS folder and we will delete it
all content except the "FactoryApp" and "prov_data" folders and turn off the phone.
4. The next step will be to flash via Odin with the Factory_Binary (Combine File) of the model to work.
5. Once the Reset is done, press the "IME" button and a keyboard will appear with which we proceed
to verify the IMEI with * # 06 # and we will see that our imei is already correct again
6. Proceed to flash with a Stock Rom and this is it, IMEI Recovered and ready to continue working.
The Following User Says Thank You to gcceleghg For This Useful Post:
Old 09-03-2018, 15:47   #4 (permalink)
Member: 1484663
Thanks Meter: 344
Unlocking OEM
thanx man. Will try and post results.
Old 09-03-2018, 16:08   #5 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
Yes, please, try to do the whole process and upload results.
CF-Auto-Root-heroqltetmo-heroqltetmo-smg930t.zip
NRD90M.G930TUVU4BQG5 7.0
https://download.chainfire.eu/982/CF...mo-smg930t.zip
COMBINATION_FA60_G930TUVU4API4.zip
https://androidfilehost.com/?fid=529152257862721890
Old 09-05-2018, 00:14   #6 (permalink)
Member: 1484663
Thanks Meter: 344
Hi friend. Didin't work for me. Sorry. SEt it's on G930TUVU4BQB1. Here's what I did:
First in order to root need to flash ENG-Boot. them sideload superSu and good to go. I erase all except the folders mentioned on efs and flash the combination. Got stuck on boot and have to make a factory reset. After that boot on Combinaion OK, reboot, but Imei remai in 000000000000000. Flash stock again and no changes.
Don't know what else to do.
Page generated in 0.17152 seconds with 8 queries
