07-23-2019, 20:59 | #1 (permalink) |
Freak Poster Join Date: May 2018
Member: 2837277 Status: Offline Thanks Meter: 39 | help problem with a750g bit 3 Chimera Mobile Phone Utility version: 21.68.1040 @ 2019-07-15 Printing phone history Patch Certificate 15/07/2019 19:56:39 SW Change 15/07/2019 19:55:30 SW Change 15/07/2019 19:52:21 Patch Certificate 15/07/2019 19:50:02 Patch Certificate 15/07/2019 19:49:17 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A750G Sales Code: CHT Country Code: Chile Timezone: America/Santiago Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Jun 12 04:25:20 KST 2019 PDA Version: A750GUBS3BSF3 [june 2019, rev3] Phone Version: A750GNDXU3ASE1 [may 2019, rev1] CSC Version: A750GOWT3BSF1 [june 2019, rev1] Product Code: CHT HIDSw Version: A750GUBS3BSF3/A750GOWT3BSF1/A750GNDXU3ASE1/A750GUBS3BSF3 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: R28KC0HNWGA Imei: 3541220XXXX Unique Number: CCU000D9E47C9B5 Connections: AT,MTP Battery Status: 3.85V (27%) Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: unencrypted Preparing... Checking current patchcert. Checking modem. Checking root. The phone is rooted by: 18.1:MAGISKSU (topjohnwu) Checking boot image. Be patient! Do NOT disconnect the phone! The knox is still valid. Because of the boot patch the warranty will void. Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... The operation is in progress. Be patient! Do NOT disconnect the phone! After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [07.15.19 16:02:19] WorkID: 66326516 I leave my record to see if someone helps me |
07-24-2019, 10:17 | #2 (permalink) |
Junior Member Join Date: Oct 2017
Member: 2770761 Status: Offline Sonork: 100.1588189 Thanks Meter: 3 | Flash only modem combination https://mega.nz/#!oolE2AIA!V01m_MRZA...lJA6PN6PAe0uqs And try again Enviado de meu SM-G9650 usando o Tapatalk |
07-24-2019, 15:30 | #3 (permalink) | |
Member: 2837277 Status: Offline Thanks Meter: 39 | Quote:
Can you upload it to mediafire please to prove that, because it gives me a signal and everything with my modem but after a few days it starts to restart | |
