07-15-2017, 08:28 | #1 (permalink) |
No Life Poster Join Date: Jan 2015 Location: Narsingdi, Dhaka, Bangladesh Age: 28
Member: 2325851 Status: Offline Sonork: 100.1680491 Thanks Meter: 2,363 | htc desire 530 unlock problem [IMG][/IMG] please help me sir how to solve it give me solution sir |
The Following User Says Thank You to pintu_das For This Useful Post: |
07-17-2017, 09:27 | #2 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Online Thanks Meter: 23,751 | reply Dear User, First of all thank you for the Feedback. We need your patient because the developers have to check the unlock method once again properly. So after that we can make a solution for this problem. That wont take too much time. Best Regards Chimera Team |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
07-19-2017, 10:34 | #3 (permalink) |
Member: 1787203 Status: Online Thanks Meter: 23,751 | reply Dear User, We made the update. Please try to do the process now and please let us know the result. It would be important for us. Best Regards Chimera Team |
08-10-2017, 21:12 | #4 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | HTC Desire 530 T-Mobile Unlock Problem. Software showing Unlocked. but still Locked Chimera Mobile Phone Utility version: 14.69.1407 @ 2017-08-10 Printing phone history Direct unlock 10-Aug-17 8:03:32 PM Direct unlock 09-Aug-17 7:37:24 PM Direct unlock 09-Aug-17 11:26:52 AM Direct unlock 08-Aug-17 2:32:17 PM Direct unlock 08-Aug-17 2:09:31 PM [Get info started] Information Phone detected IMEI: 359417071131000 GSM version: 01.01_U113251211_63.10.60527G_F Android version: 6.0.1 Model name: HTC 2PST2 Manufacturer: HTC Device code: htc_a16ul Product name: a16ul_00352 Product version: 1.01.352.25 Bootloader version: 1.0.0.0000 Language: Region: Battery: Cid: WFM__001 Main camera: Ram: 1.5GB Wifi: Protected: true Build line: A16ULTMUS_WFM_US_M601_CRC_DesireSense70GP_Stable Build changelist: 765079 Build characteristics: default Build UTC: 1466995666 Build date: 一 6月 27 10:47:46 CST 2016 Build descriptor: 1.01.352.25 CL765079 release-keys Build display id: MMB29M release-keys Build project: A16_UL_M60_DESIRE_SENSE70GP_TMUS:481250 Build Sense version: 7.0 Kernel version: Linux version 3.10.49-perf-ge03a442 (and@AABM) (gcc version 4.8 (GCC) ) #2 SMP PREEMPT Mon Jun 27 10:52:37 CST 2016  Please restart the phone in NORMAL mode Finished successfully Finished at local time: [08.10.17 20:11:44] WorkID: 24957894 Chimera Mobile Phone Utility version: 14.69.1407 @ 2017-08-10 Printing phone history Direct unlock 09-Aug-17 7:37:24 PM Direct unlock 09-Aug-17 11:26:52 AM Direct unlock 08-Aug-17 2:32:17 PM Direct unlock 08-Aug-17 2:09:31 PM [Direct unlock started] Downloading recovery image from server. Please hold on, it can take some time. Recovery image has been downloaded. Switching to fastboot mode Phone detected Checking bootloader state... Phone detected Using new method Rebooting in bootloader mode Phone detected Bootloader is unlocked Rebooting in download mode Phone detected Bootloader is already unlocked Installing recovery image Installing was successful 1.) Please select REBOOT TO BOOTLOADER option from Download mode menu 2.) Select BOOT TO RECOVERY MODE option from the BOOTLOADER menu Waiting for ADB device Initializing recovery mode Recovery mode detected, preparing phone, do not touch the phone. Preparing the phone for the procedure Calculating simlock Rebooting in recovery mode Cleaning up Information Your phone may asks for decryption password after it boots. Please type a single zero digit, then press the enter button. After that the phone will ask you for FACTORY RESET. Push the reset button, then please go to the Wipe menu in the TWRP recovery and pull the sliding bar to reset. After that you can boot into system mode and use the phone as usual. Finished successfully Finished at local time: [08.10.17 20:07:33] WorkID: 24957469 |
08-14-2017, 10:57 | #6 (permalink) | |
Member: 1787203 Status: Online Thanks Meter: 23,751 | reply Dear Sir, First of all I can offer you install the chimeratool drivers from the software. it is USA Tmobile device? (unfortunately without the drivers we can not read the regio code from the device) USA Tmobile added extra lock on the devices, that is why the unlock process successfully done (normal lock removed) but the extra tmobile lock unable to remove. At the moment we have not solution for the tmobile extra lock remove. Best regards: Nicole Quote:
10-19-2017, 12:46 | #7 (permalink) | |
Junior Member Join Date: Feb 2015 Location: Drogheda, Ireland
Member: 2343716 Status: Offline Thanks Meter: 8 | Quote:
01-28-2018, 20:54 | #8 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2698861 Status: Offline Thanks Meter: 5 | htc desire 530 trying to s-off but error is showing always..! [S-ON/S-OFF started] Checking current security flag Restarting in fastboot mode Phone detected Downloading recovery image from server. Please hold on, it can take some time. Recovery image has been downloaded. Switching to fastboot mode Phone detected Checking bootloader state... Phone detected Using new method Rebooting in bootloader mode Phone detected Bootloader is unlocked Rebooting in download mode Phone detected Bootloader is already unlocked Installing recovery image Installing was successful 1.) Please select REBOOT TO BOOTLOADER option from Download mode menu 2.) Select BOOT TO RECOVERY MODE option from the BOOTLOADER menu Waiting for ADB device Initializing recovery mode Recovery mode detected, preparing phone, do not touch the phone. Waiting for the phone... Gathering phone information Communicating with Chimera server Preparing the phone for the procedure Unable to start CCC. Finished at local time: [01.28.18 19:45:25] WorkID: 32628301 |
01-29-2018, 17:08 | #9 (permalink) | |
Member: 1787203 Status: Online Thanks Meter: 23,751 | reply Dear Sir, please try to install new firmware on the device and try again the process. Best regards Nicole Quote:
02-02-2018, 20:40 | #10 (permalink) |
Member: 2698861 Status: Offline Thanks Meter: 5 | i can't install new firmware on htc desire 530 because it's S-ON.. i want to install other firmware that's why i'm trying to S-OFF first and change CID then i can flash new firmware or other firmware.. but i'm always getting error, restarted pc and phone as well, but all the time same error.. |
