Chimera Mobile Phone Utility version: 12.10.1056 @ 2016-11-23 HTC M9 Printing phone history Remove FRP lock 11/23/2016 1:10:22 PM Remove FRP lock 11/23/2016 1:05:32 PM Remove FRP lock 11/23/2016 1:05:02 PM Remove FRP lock 11/23/2016 1:04:19 PM Remove FRP lock 11/23/2016 1:02:01 PM [Remove FRP lock started] Reading FRP information... Filed to read FRP information Finished at local time: [11.23.16 18:10:54] WorkID: 15299319 |
Dear Users, thank you for the feedbacks, we are working on it and shortly it will be fixed. Best regards Nicole |
How did you connect the phone? |
Selected Model HTC M9WLS Selected Task HTC Sprint Unlock(ADB) Searching ADB device Please wait.. Device Detected... model:= 0PJA2 Androids Version:= 6.0 Description Version:= 3.41.651.4 CL695981 release-keys Platform:= msm8994 [ htc_hima ] [ msm ] Baseband:= 3.00.C1144084@60114 Device := htc_himawhl MODEID := 0PJA20000 CID := SPCS_001 PROJECT := HIMA_WHL_M60_SENSE70_SPCS_MR Simstatus:= ABSENT ANDROID-ID = HT53PSV09516_0000F21BE6 Device is not rooted HTC SPRINT UNLOCKING STARTED... !!! Fail !!!! Restarted phone... Total Time Take...00:00:44 Log Saved m9 sprint 6.0 sported unlock with chimera tool |
Htc 728g when try to reset FRP: Chimera Mobile Phone Utility version: 12.10.1702 @ 2016-11-24 Printing phone history Remove FRP lock 24.11.2016. 11:28:33 Remove FRP lock 24.11.2016. 10:49:12 [Remove FRP lock started] Reading FRP information... Calculating FRP response...  This may take a while.  Be patient! Do NOT disconnect the phone! Writing FRP response... Rebooting the device... Finished successfully Finished at local time: [11.24.16 12:45:27] WorkID: 15329301  ADB error! Please close all other ADB dependent programs! (eg. root program) BUT during unlock ( that is not done, because can't reset, and can't enter recowery menu, it show only red triangle ), My antivirus detect and block file : evbF801.tmp as Trojan.Gen.SMH.2 . HOw to resolve that ? |
reply Dear Sir, can we check the problem via teamviewer? If yes please send us the teamviewer id and password in private message. It will be really helpful us. Thank you in advance! Best regards Nicole Quote:
Think my basic problem solved , thinked that FRP block hard reset menu, but seem to be different reason: Hi, trayed to hard reset phone, because forgot pattern . When press VOLUME DOWN + Power, it appears some menu ( seem like recovery, but it write dovnload )... but there is no line FACTORY RESET . and is writed down something about SD MOUNT.... From that Menu, trayed to go on BOTLOADER, to find RECOVERY ... and it restart to botloader menu, here found reboot ro RECOVERY Reboot to RECOVERY finish with icon of phone with red triangle with exclamation mark. Trayed volume up + power, but nothing happened.... In one moment, I insert SD card in phone, once again try to start phone with VOLUME DOWN + POWER; AND ... NOW IS SHOWED FACTORY RESET LINE ! After that, all is proceeded like usualy... |
I HAVE htc m9 ( himauhl ) is supported for unlock network GSM version: 01.01_U11440792_95.00.51130G_F Android version: 6.0 Model name: HTC One M9 Manufacturer: HTC Device code: htc_himauhl Product name: himauhl_orange_uk Product version: 3.35.61.14 Bootloader version: 1.0.0.0000 Language: Region: Battery: Cid: ORANG001 Main camera: Ram: 3GB Wifi: 802.11 a/b/g/n/ac Protected: true Build line: HIMAUHL_Orange_UK_M60_CRC_Sense70_Stable_MR2 Build changelist: 670363 Build characteristics: default Build UTC: 1454562192 Build date: 四 2月 4 13:03:12 CST 2016 Build descriptor: 3.35.61.14 CL670363 release-keys Build display id: MRA58K release-keys Build project: HIMA_UHL_M60_SENSE70_MR:470526 Build Sense version: 7.0 Kernel version: Linux version 3.10.84-perf-gee3cb7b (and@AABM) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP PREEMPT Thu Feb 4 13:02:42 CST 2016 |
this is not Chimera Tool post this is gcprop key |
HTC M9 Chimera Mobile Phone Utility version: 12.26.1209 @ 2016-12-10 [IMEI repair started] Rebooting in HTCFastBoot mode Phone detected Current security state: 3 Checking current security flag Downloading recovery image from server. Please hold on, it can take some time. Recovery image has been downloaded. Switching to fastboot mode Phone detected Bootloader unlock is required, asking server for access Gathering bootloader informations All user data will be lost and the phone will reset to factory default! You will see the disclaimer on the screen now. Please read this carefully as this action may void your warranty. Please select 'Yes' to continue the procedure. Use the volume buttons to highlight your choice and the Power button to make your selection (If you select Yes, your phone will be reset to its factory default settings, and your bootloader will be unlocked.If you select No, your phone will reboot and no modifications will have been made.) Waiting for bootloader unlock to finish Fastboot detached. 1.) When the HTC logo appears on the screen, 1.) Please switch to BOOTLOADER mode by pressing the VOLUME UP and POWER buttons until the screen will be blank 2.) Then quickly release them and press VOLUME DOWN and POWER until the BOOTLOADER menu comes on. 2.) Then select DOWNLOAD mode by VOLUME+/- then press POWER button Phone detected Installing recovery image Installing was successfull Switch to recovery mode 1.) Please select REBOOT TO BOOTLOADER option from Download mode menu 2.) Select BOOT TO RECOVERY MODE option from the BOOTLOADER menu Waiting for ADB device Recovery mode detected, preparing phone, do not touch the phone. Gathering phone informations Communicating with Chimera server Preparing the phone for the procedure Calculating encrypted datas Rebooting in recovery mode 1.) Please switch to DOWNLOAD mode by pressing the VOLUME UP and POWER buttons until the screen will be blank 2.) Then quickly release them and press VOLUME DOWN until the DOWNLOAD menu comes on. 3.) Please select BOOTLOADER option, then boot into RECOVERY mode. Cleaning up Checking Current security flag: 0 Informations Your phone may asks for decryption password after it boots. Please type a single zero digit, then press the enter button. After that the phone will ask you for FACTORY RESET. Push the reset button, then please go to the Wipe menu in the TWRP recovery and pull the sliding bar to reset. After that you can boot into system mode and use the phone as usual. Restarting in HTCFastBoot mode Phone detected Writing IMEI(s) IMEI 1 to write: 35xxxxxxxxxxxxx Checking current security flag Writing security flag Phone detected Security flag has been written: S-ON Finished successfully Finished at local time: [12.10.16 14:41:07] |
MTK models added 17/12/2016 ChimeraTool new HTC module Update: v 12.33.1729 17/12/2016
htc d816d is it supported??????? |
we need suppor for HTC 626s from metro pcs |
reply Dear User, We will forward your request to the Developer Team. Hopefully we can help you out with that model in the near Future. Best Regards Chimera Team Quote:
