Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 11-23-2016, 13:14   #31 (permalink)
Member: 2451024
Sonork: 100.1670074
Thanks Meter: 15
Chimera Mobile Phone Utility version: 12.10.1056 @ 2016-11-23
HTC M9
Printing phone history
Remove FRP lock
11/23/2016
1:10:22
PM
Remove FRP lock
11/23/2016
1:05:32
PM
Remove FRP lock
11/23/2016
1:05:02
PM
Remove FRP lock
11/23/2016
1:04:19
PM
Remove FRP lock
11/23/2016
1:02:01
PM
[Remove FRP lock started]
Reading FRP information...
Filed to read FRP information
Finished at local time: [11.23.16 18:10:54]
WorkID: 15299319
Old 11-23-2016, 16:04   #32 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 14,357
Dear Users,
thank you for the feedbacks, we are working on it and shortly it will be fixed.
Best regards
Nicole
Old 11-23-2016, 20:06   #33 (permalink)
Member: 1385989
How did you connect the phone?
Old 11-24-2016, 06:58   #34 (permalink)
worldlinkmobil's Avatar
Member: 1275418
Thanks Meter: 369
Selected Model HTC M9WLS
Selected Task HTC Sprint Unlock(ADB)
Searching ADB device Please wait..
Device Detected...
model:= 0PJA2
Androids Version:= 6.0
Description Version:= 3.41.651.4 CL695981 release-keys
Platform:= msm8994 [ htc_hima ] [ msm ]
Baseband:= [email protected]
Device := htc_himawhl
MODEID := 0PJA20000
CID := SPCS_001
PROJECT := HIMA_WHL_M60_SENSE70_SPCS_MR
Simstatus:= ABSENT
ANDROID-ID = HT53PSV09516_0000F21BE6
Device is not rooted
HTC SPRINT UNLOCKING STARTED...
!!! Fail !!!!
Restarted phone...
Total Time Take...00:00:44
Log Saved
m9 sprint 6.0 sported unlock with chimera tool
Old 11-24-2016, 11:49   #35 (permalink)
Crumarix1's Avatar
Member: 84300
Thanks Meter: 71
Htc 728g
when try to reset FRP:
Chimera Mobile Phone Utility version: 12.10.1702 @ 2016-11-24
Remove FRP lock
24.11.2016.
11:28:33
Remove FRP lock
24.11.2016.
10:49:12
Calculating FRP response...
 This may take a while.
 Be patient! Do NOT disconnect the phone!
Writing FRP response...
Rebooting the device...
Finished successfully
Finished at local time: [11.24.16 12:45:27]
WorkID: 15329301
 ADB error! Please close all other ADB dependent programs! (eg. root program)
BUT during unlock ( that is not done, because can't reset, and can't enter recowery menu, it show only red triangle ), My antivirus detect and block file : evbF801.tmp as Trojan.Gen.SMH.2 .
HOw to resolve that ?
Old 11-24-2016, 12:46   #36 (permalink)
Member: 1787203
reply
Dear Sir,
can we check the problem via teamviewer?
If yes please send us the teamviewer id and password in private message.
It will be really helpful us.
Thank you in advance!
Best regards
Nicole
Remove FRP lock
24.11.2016.
11:28:33
Remove FRP lock
24.11.2016.
10:49:12
WorkID: 15329301
Old 11-25-2016, 09:18   #37 (permalink)
Crumarix1's Avatar
Member: 84300
Thanks Meter: 71
Think my basic problem solved , thinked that FRP block hard reset menu, but seem to be different reason:
Hi, trayed to hard reset phone, because forgot pattern .
When press VOLUME DOWN + Power, it appears some menu ( seem like recovery, but it write dovnload )... but there is no line FACTORY RESET . and is writed down something about SD MOUNT....
From that Menu, trayed to go on BOTLOADER, to find RECOVERY ... and it restart to botloader menu, here found reboot ro RECOVERY
Reboot to RECOVERY finish with icon of phone with red triangle with exclamation mark. Trayed volume up + power, but nothing happened....
In one moment, I insert SD card in phone, once again try to start phone with VOLUME DOWN + POWER;
AND ...
NOW IS SHOWED FACTORY RESET LINE !
After that, all is proceeded like usualy...
Old 11-26-2016, 13:19   #38 (permalink)
gsmsalik's Avatar
Member: 207447
Thanks Meter: 44
I HAVE htc m9 ( himauhl ) is supported for unlock network
GSM version: 01.01_U11440792_95.00.51130G_F
Android version: 6.0
Model name: HTC One M9
Manufacturer: HTC
Device code: htc_himauhl
Product name: himauhl_orange_uk
Product version: 3.35.61.14
Bootloader version: 1.0.0.0000
Language:
Region:
Battery:
Cid: ORANG001
Main camera:
Ram: 3GB
Wifi: 802.11 a/b/g/n/ac
Protected: true
Build line: HIMAUHL_Orange_UK_M60_CRC_Sense70_Stable_MR2
Build changelist: 670363
Build characteristics: default
Build UTC: 1454562192
Build date: 四 2月 4 13:03:12 CST 2016
Build descriptor: 3.35.61.14 CL670363 release-keys
Build display id: MRA58K release-keys
Build project: HIMA_UHL_M60_SENSE70_MR:470526
Build Sense version: 7.0
Kernel version: Linux version 3.10.84-perf-gee3cb7b ([email protected]) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #1 SMP PREEMPT Thu Feb 4 13:02:42 CST 2016
Old 11-27-2016, 13:47   #39 (permalink)
Member: 1275418
Thanks Meter: 369
Old 11-27-2016, 13:49   #40 (permalink)
Member: 1275418
Thanks Meter: 369
this is not Chimera Tool post this is gcprop key
Old 12-10-2016, 15:24   #41 (permalink)
Member: 871125
Sonork: 1607190
Thanks Meter: 72
HTC M9
Chimera Mobile Phone Utility version: 12.26.1209 @ 2016-12-10
[IMEI repair started]
Rebooting in HTCFastBoot mode
Phone detected
Current security state: 3
Checking current security flag
Downloading recovery image from server.
Please hold on, it can take some time.
Recovery image has been downloaded.
Switching to fastboot mode
Phone detected
Bootloader unlock is required, asking server for access
Gathering bootloader informations
All user data will be lost and the phone will reset to factory default!
You will see the disclaimer on the screen now. Please read this carefully as this action may void your warranty.
Please select 'Yes' to continue the procedure. Use the volume buttons to highlight your choice and the Power button to make your selection
(If you select Yes, your phone will be reset to its factory default settings, and your bootloader will be unlocked.If you select No, your phone will reboot and no modifications will have been made.)
Waiting for bootloader unlock to finish
Fastboot detached.
1.) When the HTC logo appears on the screen,
1.) Please switch to BOOTLOADER mode by pressing the VOLUME UP and POWER buttons until the screen will be blank
2.) Then quickly release them and press VOLUME DOWN and POWER until the BOOTLOADER menu comes on.
2.) Then select DOWNLOAD mode by VOLUME+/- then press POWER button
Phone detected
Installing recovery image
Installing was successfull
Switch to recovery mode
1.) Please select REBOOT TO BOOTLOADER option from Download mode menu
2.) Select BOOT TO RECOVERY MODE option from the BOOTLOADER menu
Waiting for ADB device
Recovery mode detected, preparing phone, do not touch the phone.
Gathering phone informations
Communicating with Chimera server
Preparing the phone for the procedure
Calculating encrypted datas
Rebooting in recovery mode
1.) Please switch to DOWNLOAD mode by pressing the VOLUME UP and POWER buttons until the screen will be blank
2.) Then quickly release them and press VOLUME DOWN until the DOWNLOAD menu comes on.
3.) Please select BOOTLOADER option, then boot into RECOVERY mode.
Cleaning up
Checking
Current security flag: 0
Informations
Your phone may asks for decryption password after it boots.
Please type a single zero digit, then press the enter button. After that the phone will ask you for FACTORY RESET. Push the reset button, then please go to the Wipe menu in the TWRP recovery and pull the sliding bar to reset.
After that you can boot into system mode and use the phone as usual.
Restarting in HTCFastBoot mode
Phone detected
Writing IMEI(s)
IMEI 1 to write: 35xxxxxxxxxxxxx
Writing security flag
Phone detected
Security flag has been written: S-ON
Finished at local time: [12.10.16 14:41:07]
Old 12-17-2016, 14:36   #42 (permalink)
Member: 1787203
MTK models added 17/12/2016
ChimeraTool new HTC module
Update: v 12.33.1729
17/12/2016
  • IMEI Repair, Direct Unlock, Read INFO:
  • Desire 620G Dual Sim (htc_a31mg_dug)
  • Desire 320 (htc_a32mg_dug)
  • Desire 820G PLUS Dual Sim (htc_a50mgp_dug)
  • Desire 816G Dual Sim (htc_a5mgp_dug)
  • Desire 816G (htc_a5mgp_u)
  • Desire 210 Dual Sim (htc_v0_dug)
Old 12-17-2016, 17:30   #43 (permalink)
Member: 935112
Sonork: 100.1675738
Thanks Meter: 15
htc d816d is it supported???????
Old 12-19-2016, 06:26   #44 (permalink)
yocomic's Avatar
Member: 1948841
Sonork: yocomic
Thanks Meter: 41
we need suppor for HTC 626s from metro pcs
Old 12-20-2016, 11:18   #45 (permalink)
Member: 1787203
reply
Dear User,
We will forward your request to the Developer Team. Hopefully we can help you out with that model in the near Future.
Best Regards
Chimera Team
Page generated in 0.57838 seconds with 7 queries
