06-06-2018, 08:33 | #1 (permalink) |
No Life Poster Join Date: Nov 2015 Location: DHAKA
Member: 2489690 Status: Offline Thanks Meter: 289 | huawei dig-al00 huawei id error Printing phone history FRP Remove 6/6/2018 7:27:13 AM [Removing factory reset protection...] Collecting information about the device... Removing factory reset protection lock... This way did not work. Removing factory reset protection lock... This way did not work. Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... This way did not work. Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... This way did not work. Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... This way did not work. Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... This way did not work. Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... This way did not work. Factory challenge-response is failed. Finished at local time: [06.05.18 23:28:43] WorkID: 38876922 does chimera support this model or not supported for huawei id |
