07-02-2018, 13:16 | #1 (permalink) |
Freak Poster Join Date: Dec 2015 Location: GREAT YAR*****
Member: 2495115 Status: Offline Thanks Meter: 34 | Huawei p20 lite ANE LX1 I enabled Developer options and also USB Debugging BUT when I connect the phone I get "Unknown Android in UNAUTHORIZED mode" Although the phone screen shows USB debugging toggle and I have clicked this as soon as I plug in the cable the USB debugging line greys out! Any ideas as if I cannot enable USB debugging I cannot unlock Thank you for any help Steve |
07-02-2018, 13:49 | #2 (permalink) |
Member: 2495115 Status: Offline Thanks Meter: 34 | Model: ANE-L01 MEID: 00000000000000 pESN: 00000000 IMEI: 867906036010205 IMEI 0: 000000000000000 IMEISV: 02 Firmware ver.: System 8.0.0.046(07RH) SN: 89UDU18516001455 Custom SN: DU4VYH185F127440 WiFi MAC: A0:57:E3:09:C0F BlueTooth MAC: A0:57:E3:09:C4:C8 Vendor: ee Country: gb FASTBOOT:Chipset-dallas8.0.0.001(01YG)_FASTBOOT BOOT:System 8.0.0.046(07RH)_BOOT RECOVERYunknow) SYSTEM:System 8.0.0.046(07RH) MAINVER:System 8.0.0.046(07RH) DATAVER:ANE-LX1 8.0.0.103(C782)_DATA_ANE-L01_hw_eu APTIME:Sat Mar 24 12:25:07 CST 2018 RAM: 4G eMMC: 64G IMEI 1 Sim Lock status: NET: locked, unlock retry counts: 10 NETSUB: unlocked SP: unlocked 2018-07-02 13:31:44.296 Autodetect started! 2018-07-02 13:31:46.979 Found COM port: COM13 2018-07-02 13:31:47.131 Connecting to server... 2018-07-02 13:31:49.409 ERROR! Connection error 138 |
The Following User Says Thank You to Stevefilby For This Useful Post: |
07-02-2018, 15:47 | #3 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,782 | reply Hi, could you write me the work id of the log please? Are you sure it is chimera log? Best regards Nicole Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
07-02-2018, 15:52 | #4 (permalink) |
Member: 2495115 Status: Offline Thanks Meter: 34 | SORRY this log is from my attempt at unlock with my Furious box ???? posted here in error. In Chimera i cannot connect all I get is the "huawei phone connected in unauthorised mode" screen Steve |
07-03-2018, 13:13 | #5 (permalink) |
Member: 2495115 Status: Offline Thanks Meter: 34 | Sorry just re visiting this problem I have no log in Chimera as the phone does not display "allow USB debugging" screen until this displays I cannot get the adb to collect? Thank you Steve |
07-03-2018, 14:12 | #6 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,782 | reply Hi Steve, Can we check your case via teamviewer please? Please contact us on support chat if it is possible. Best regards Nicole |
07-04-2018, 07:58 | #7 (permalink) |
Member: 2495115 Status: Offline Thanks Meter: 34 | Sorry had to return phone to customer. Only information I have retained is in the Furious log above. I think the problem with this handset is that there is a lock/block somewhere that is preventing the "allow Usb debugging" therefor the phone cannot be authorized to allow the ADB to run????? Thank you for your help Steve BTW Infinity couldn't unlock this either, although ot too managed a connection |
07-04-2018, 08:04 | #8 (permalink) |
Freak Poster Join Date: Nov 2017 Location: midrand
Member: 2783412 Status: Offline Sonork: 1680285 Thanks Meter: 226 | whenever you face this problem,go to developer options and turn off OEM lock, when you will turn off OEM unlock immediately pop up will appear asking for usb debugging permission, allow usb debugging and immediately turn on OEM lock, tested by me |
The Following 5 Users Say Thank You to choksi For This Useful Post: |
05-06-2019, 16:49 | #10 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,782 | reply Hi, in a most cases when you get the follow error message: "The device sent an invalid challenge Retry 2/5 Authentication with the device failed" the problem comes from the new Huawei Key, firmware, the chimera tool is not supporting that version right now, but we are working on it already. |
