07-09-2020, 16:27 | #451 (permalink) |
Junior Member Join Date: Sep 2012 Location: EU
Member: 1811050 Status: Offline Thanks Meter: 15 | Remove FRP Lock process (Kirin 980/710/970/960/etc..) : 1. Step: Click "Load Factory Fastboot" button 2. Step: Click "Remove FRP Lock" button 3. Step: Click "Boot Repair" button or Repair Recovery (if available) If you used the "Boot Repair" procedure, after the process you MUST run USB Software Update or Repair Recovery (if available) on the device. |
07-09-2020, 19:00 | #452 (permalink) | |
Junior Member Join Date: Dec 2016 Location: dsadasdasd
Member: 2656482 Status: Offline Sonork: facebook.com/maliksaqib01 Thanks Meter: 10 | Quote:
07-09-2020, 20:48 | #456 (permalink) | |
Freak Poster Join Date: May 2014 Location: Africa
Member: 2179221 Status: Offline Sonork: 100.1685104 Thanks Meter: 66 | Thx for this Quote:
BOSS Failed to authenticate; phone has improved security Please improved security like P10, Vtr-l29 Add COM 1.0 Write Flash | |
07-09-2020, 20:59 | #457 (permalink) | |
Member: 1811050 Status: Offline Thanks Meter: 15 | Quote:
"Add COM 1.0 Write Flash" --> Use the "Load Factory Fastboot" procedure, just click to the button. After the phone will in Fastboot mode (authenticated) and you can use the fastboot methods, like write flash = Software Update Or better (i think) if you use the Repair Recovery and after the USB Software Update function. And khm.. Please read before write.. i asked before "What do you want to do with phone ?" Only software repair ? Which procedure did you used when received the error message? | |
07-10-2020, 02:01 | #460 (permalink) | |
Freak Poster Join Date: Mar 2016
Member: 2542848 Status: Offline Thanks Meter: 80 | Quote:
but this update can Repair IMEI after unbrick phone on Kirin 990, 980, 710, etc ? | |
