12-03-2020, 15:55 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | SM-A105F ''U4'' Patch certificate Done Chimera Mobile Phone Utility version: 26.79.1429 @ 2020-12-03 Printing phone history Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A105F Carrier ID: XFA Sales Code: INS Country Code: India Timezone: Africa/Johannesburg Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Aug 24 16:39:43 KST 2020 PDA Version: A105FDDU4BTH5 [august 2020, rev5] Phone Version: A105FDDU4BTG1 [july 2020, rev1] CSC Version: A105FODM4BTH5 [august 2020, rev5] Board Platform: UNIVERSAL7884B Modem Platform: SHANNON327 Serial Number: RF8M4192G8W Imei: 35 Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-08-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 35 Repaired imei: 35 Successfully finished. Finished at local time: [12.03.20 16:47:14] WorkID: 117499587 Chimera Mobile Phone Utility version: 26.79.1429 @ 2020-12-03 Printing phone history Reboot 12/3/2020 2:50 PM Patch Certificate 12/3/2020 2:48 PM Repair IMEI 12/3/2020 2:45 PM Repair IMEI 12/3/2020 1:12 PM Repair IMEI 12/3/2020 1:06 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A105F Carrier ID: XFA Sales Code: INS Country Code: India Timezone: Africa/Johannesburg Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Mon Aug 24 16:39:43 KST 2020 PDA Version: A105FDDU4BTH5 [august 2020, rev5] Phone Version: A105FDDU4BTG1 [july 2020, rev1] CSC Version: A105FODM4BTH5 [august 2020, rev5] Board Platform: UNIVERSAL7884B Modem Platform: SHANNON327 Serial Number: RF8M4192G8W Imei: 35 Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-08-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.03.20 16:52:46] WorkID: 117500696 |
The Following User Says Thank You to ..::GMSR::.. For This Useful Post: |
