07-28-2014, 21:25 | #1 (permalink) |
Freak Poster Join Date: Mar 2011 Location: I`m From Cancun Age: 34
Member: 1538766 Status: Offline Sonork: 1626907 Thanks Meter: 18 | I need support for s5 sprint i try flashing with stock rom android 4.4.2 with odin, and although the process is finished the s5 is the same problem, I try to make a hard reset but this phone not enter in recovery mode only restart in samsung. i need unbrick this phone Thanks Last edited by josepuc; 07-28-2014 at 21:34. |
07-29-2014, 02:39 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | This can be applied on any model of Galaxy S5 including the following. In case your Samsung Galaxy S5 does not boot into Recovery mode with these steps, remove the battery and re-insert it after a few seconds. G900F/SM-G900H - for Europe SM-G900I : Asia SM-G900K/G900L/G900S: for Korea SM-G900M: Vodafone SM-G900A: AT&T SM-G900T: T-Mobile SM-G900V: Verizon SM-G900R4: US Cellular SM-G900P: Sprint If you have rooted your Samsung Galaxy S5 smartphone, and have installed some custom recovery tool like TWRP or CWM, you can boot it in Custom Recovery using apps such as GooManager for TWRP Recovery and ROM Manager for CWM Recovery. These both might not support the very latest Samsung Galaxy S5 at the moment, but you should expect support as soon as device is launched internationally. |
07-29-2014, 02:45 | #3 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | This has been a problem for me as well. I've used TWRP 2.5.0.2 and the 2.6.x.x versions with the same issue. Typically only happens after flashing an AOSP based ROM then restoring a TW nandroid. For me, one of the partitions gets corrupted, I've had /data and /system both get borked. Formatting in TWRP and CWM does nothing to fix the problem. My only solution so far has been to ODIN crawjs rooted stock MF9 .tar and factory reset in stock recovery. This seems to restore the partition. After that, reboot into download again and flash TWRP 2.5.0.2 .tar. Only then can I successfully restore a previous Nandroid. It's weird, the first boot always works. Haven't heard a definitive answer to why this happens. I may experiment flashing an AOSP with CWM and see if the same issue persists. This is a help maybe you can serve, but I trust that the excellent team of Chimera will help you |
07-29-2014, 12:20 | #4 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,783 | answer Dear josepuc, your phone is working on normal mode or not? tried to use the recovery mode with adb reboot recovery? Kind regards, Chimera Team Quote:
07-30-2014, 22:59 | #7 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1634859 Status: Offline Thanks Meter: 0 | unlock i find mode to activate mode unlock by code , i request code and i received , but i can't insert in phone . help please . my imei is 990004477409134 and code for unlock is NETWORK=16094904 PROVIDER=10761645 SUBPROVIDER=13865065 DEFREEZE=59804449 EXTRA=00000000 |
08-01-2014, 23:18 | #9 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: In a point from Universe! Age: 40
Member: 235325 Status: Offline Sonork: 100.1593552 Thanks Meter: 523 | Quote:
When you type *#0011# what message you see at NETWORK? | |
08-05-2014, 02:37 | #11 (permalink) |
Freak Poster Join Date: May 2005 Location: Ghana Age: 53
Member: 147362 Status: Offline Thanks Meter: 11 | as i said in previous post too ! this fone is cdma . even if u get unlock code then also there is no way u can enter in fone .. because when u insert wrong simcard it doesnt ask for unlock code it simply shows INVALID SIMCARD |
