11-05-2019, 13:40 | #20 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2682248 Status: Offline Thanks Meter: 1 | It seems team are actually playing games with this model asked 3 times just today and they closed chat with no response!! How rude, opened chimera to attempt to find they added October 2019 solution that's a joke and doesn't work Work I'd 78210802 |
11-05-2019, 15:06 | #21 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,781 | reply Hi, please try again the latest version: http://forum.gsmhosting.com/vbb/f898...hcert-2245229/ Best regards Nicole |
11-07-2019, 09:33 | #24 (permalink) |
Freak Poster Join Date: Jul 2019 Location: Pakistan
Member: 2919541 Status: Offline Sonork: Tasawariqbal110 Thanks Meter: 50 | Chimera Mobile Phone Utility version: 22.88.1025 @ 2019-11-07 Printing phone history Patch Certificate 11/7/2019 8:26:09 AM Knoxguard Unlock 11/7/2019 8:24:01 AM Patch Certificate 11/7/2019 8:16:28 AM Repair IMEI 11/7/2019 8:14:42 AM Knoxguard Unlock 11/7/2019 8:09:25 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J600F Sales Code: XSG Country Code: PAKISTAN Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Jun 12 19:27:35 KST 2019 PDA Version: J600FXXU4BSF5 [june 2019, rev5] Phone Version: J600FXXU4BSF5 [june 2019, rev5] CSC Version: J600FOJM4BSF5 [june 2019, rev5] Product Code: PAK HIDSw Version: J600FXXU4BSF5/J600FOJM4BSF5/J600FXXU4BSF5/J600FXXU4BSF5 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RF8K51R600H Imei: 352205089842099 Unique Number: CBJ001BF7C0C135 Connections: AT,MTP Battery Status: 3.77V (5%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 19.1:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.07.19 13:33:33] WorkID: 78483585 |
11-07-2019, 09:34 | #25 (permalink) |
Member: 2919541 Status: Offline Sonork: Tasawariqbal110 Thanks Meter: 50 | world first Chimera Mobile Phone Utility version: 22.88.1025 @ 2019-11-07 Printing phone history Patch Certificate 11/7/2019 8:26:09 AM Knoxguard Unlock 11/7/2019 8:24:01 AM Patch Certificate 11/7/2019 8:16:28 AM Repair IMEI 11/7/2019 8:14:42 AM Knoxguard Unlock 11/7/2019 8:09:25 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J600F Sales Code: XSG Country Code: PAKISTAN Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Jun 12 19:27:35 KST 2019 PDA Version: J600FXXU4BSF5 [june 2019, rev5] Phone Version: J600FXXU4BSF5 [june 2019, rev5] CSC Version: J600FOJM4BSF5 [june 2019, rev5] Product Code: PAK HIDSw Version: J600FXXU4BSF5/J600FOJM4BSF5/J600FXXU4BSF5/J600FXXU4BSF5 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RF8K51R600H Imei: 352205089842099 Unique Number: CBJ001BF7C0C135 Connections: AT,MTP Battery Status: 3.77V (5%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 19.1:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.07.19 13:33:33] WorkID: 78483585 |
The Following User Says Thank You to Tasawariqbal For This Useful Post: |
11-09-2019, 08:22 | #26 (permalink) |
Member: 2919541 Status: Offline Sonork: Tasawariqbal110 Thanks Meter: 50 | j600f u4 world first Chimera Mobile Phone Utility version: 22.88.1025 @ 2019-11-07 Printing phone history Patch Certificate 11/7/2019 8:26:09 AM Knoxguard Unlock 11/7/2019 8:24:01 AM Patch Certificate 11/7/2019 8:16:28 AM Repair IMEI 11/7/2019 8:14:42 AM Knoxguard Unlock 11/7/2019 8:09:25 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J600F Sales Code: XSG Country Code: PAKISTAN Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Jun 12 19:27:35 KST 2019 PDA Version: J600FXXU4BSF5 [june 2019, rev5] Phone Version: J600FXXU4BSF5 [june 2019, rev5] CSC Version: J600FOJM4BSF5 [june 2019, rev5] Product Code: PAK HIDSw Version: J600FXXU4BSF5/J600FOJM4BSF5/J600FXXU4BSF5/J600FXXU4BSF5 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RF8K51R600H Imei: 352205089842099 Unique Number: CBJ001BF7C0C135 Connections: AT,MTP Battery Status: 3.77V (5%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 19.1:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.07.19 13:33:33] WorkID: 78483585 |
