06-22-2017, 23:47 | #1 (permalink) |
No Life Poster Join Date: Nov 2005
Member: 199538 Status: Offline Thanks Meter: 54 | J700T1 j700t1uvu3aqc3 impossible FRP !!! Any idea for FRP... remember.. any ENG boot available stuck the phone any idea support !!! |
06-23-2017, 02:22 | #3 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
Dear user! Here are the supported functions for your model: Samsung Galaxy J7 Model: SM-J700T1 Supported features ✓ SW Change ✓ Unlock ✓ Read Codes ✓ Repair IMEI ✓ Info ✓ Root / Unroot ✓ Read / Write certificate ✓ Restore / Store backup ✓ Reset FRP Lock ✓ Reset Screen Lock ✓ Repair Device Root Key ✓ Firmware Compatibility ✓ Patch Certificate ✓ Reboot ✓ Device Info Use this file to FRP procedure and flash using Odin FRP with Chimera Reset FRP Lock option https://www.4shared.com/file/MzlcMuMrce/boot.html If it does not get a positive result, then use RealTerm. | |
06-23-2017, 12:58 | #4 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,746 | reply Dear Sir, please send us the work id of the unsuccessful frp lock remove process and we can check how can we help you to solve that issue. Best regards Nicole Quote:
06-23-2017, 20:11 | #5 (permalink) |
Member: 199538 Status: Offline Thanks Meter: 54 | [Reset FRP lock started] Selected model: SM-J700T1 Resetting FRP by engineering boot based method. Processing... Processing. Be patient! Do NOT disconnect the phone! After reboot if the boot process get stuck, you can install a stock firmware. Checking custom root image... Present. Rooting by custom image based root method... Flashing firmware... Waiting for download mode. Connecting. SBL Info: Modelo: SM-J700T1, Region: USA, Provider: MTR, PDA: J700T1UVU3AQC3 Reading PIT. Flashing boot.img Restarting phone. Waiting for device. Be patient! Do NOT disconnect the phone! PHONE FLASHING ALL THE TIME... !!!! Reviving with Full flash !!!! etc etc |
06-23-2017, 20:36 | #6 (permalink) | |
The truth is I do not know if there are files of combination with binary: 3 The ones that are there are these: J700T, T1_COMBINATION_TMB_FA60_J700TUVU1APF2_FACTORY_REV00_user_mid_noship.rar J700T, T1_COMBINATION_TMB_FA60_J700TUVU2API1_FACTORY_user_mid_noship.tar.rar | |
08-29-2017, 19:05 | #7 (permalink) |
Freak Poster Join Date: Feb 2016
Member: 2529775 Status: Offline Thanks Meter: 68 | Use this boot image to enable adb https://drive.google.com/file/d/0B9-...ew?usp=sharing |
The Following 6 Users Say Thank You to kbdaking1 For This Useful Post: |
