02-14-2019, 19:52 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: GSM World!! Age: 35
Member: 1530237 Status: Offline Sonork: 100.1614868 Thanks Meter: 5,598 | J7prime "SM-G610M" Binary 3!! Teste Files for IMEI repair- Here Solution Chimera Tool Firmware 7.0 Stock Binary3 + ENG Modem Bin3 https://drive.google.com/drive/folde...4a?usp=sharing This Was tested for me!! PATCH SUCCESS Code: Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G610M Sales Code: CTI Country Code: Argentina Timezone: America/Bogota Android Version: 7.0 [NRD90M] [SDK 24] Build Date: Tue Nov 6 00:45:09 KST 2018 PDA Version: G610MUBU3BRK1 [november 2018, rev1] Phone Version: G610MUBU3CRJ1 [october 2018, rev1] CSC Version: G610MUWA3BRK1 [november 2018, rev1] Product Code: CTI HIDSw Version: G610MUBU3BRK1/G610MUWA3BRK1/G610MUBU3CRJ1/G610MUBU3BRK1 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: R58JB4AAXJP Imei: 353771099999900 Unique Number: CAJ00BEBEEC62A4 Connections: AT,MTP Battery Status: 4.26V (100%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2018-11-01 Data Encryption State: encrypted Preparing... Checking current patchcert. Checking modem. Checking root. Checking boot image. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... Communicating with the server. Be patient! Do NOT disconnect the phone! After the process, the phone can restart once during startup. Within 20-70 seconds after the phone starts, the signal strength indicator will toggle: signal -> no signal -> signal. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [02.13.19 11:46:37] IMEI REPAIR Code: Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G610M Sales Code: CTI Country Code: Argentina Timezone: America/Bogota Android Version: 7.0 [NRD90M] [SDK 24] Build Date: Tue Nov 6 00:45:09 KST 2018 PDA Version: G610MUBU3BRK1 [november 2018, rev1] Phone Version: G610MUBU3CRJ1 [october 2018, rev1] CSC Version: G610MUWA3BRK1 [november 2018, rev1] Product Code: CTI HIDSw Version: G610MUBU3BRK1/G610MUWA3BRK1/G610MUBU3CRJ1/G610MUBU3BRK1 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: R58JB4AAXJP Imei: 353771099999996 Unique Number: CAJ00BEBEEC62A4 Connections: AT,MTP Battery Status: 4.20V (94%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2018-11-01 Data Encryption State: unencrypted Repair imei... Checking modem version. Reading data. Be patient! Do NOT disconnect the phone! Repaired IMEI: 353771099999900 If necessary, use the patch cert procedure. Succeeded. Successfully finished. Finished at local time: [02.13.19 10:41:28] Best Regards!! resident2011 Oops, something lost |
The Following 12 Users Say Thank You to resident2011 For This Useful Post: |
02-25-2019, 20:55 | #6 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 376826 Status: Offline Thanks Meter: 9 | I flash the phone with the files but it does not allow me to repair imei and on the screen of the phone it appears MODEM CRASH!!!!! Chimera Mobile Phone Utility version: 20.31.1427 @ 2019-02-25 Printing phone history Repair IMEI 25/02/2019 07:07:40 p.m. Repair IMEI 25/02/2019 07:05:04 p.m. Root/Unroot 25/02/2019 06:56:38 p.m. Repair IMEI 25/02/2019 06:49:05 p.m. Repair IMEI 25/02/2019 06:44:53 p.m. Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G610M Sales Code: CTI Country Code: Argentina Timezone: America/Bogota Android Version: 7.0 [NRD90M] [SDK 24] Build Date: Tue Nov 6 00:45:09 KST 2018 PDA Version: G610MUBU3BRK1 [november 2018, rev1] Phone Version: G610MUBU3BRK1 [november 2018, rev1] CSC Version: G610MUWA3BRK1 [november 2018, rev1] Product Code: CTI HIDSw Version: G610MUBU3BRK1/G610MUWA3BRK1/G610MUBU3BRK1/G610MUBU3BRK1 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: R58K24EQB7V Imei: 357715086202316 Unique Number: C000064DE6A6AC4 Connections: AT,MTP Battery Status: 3.89V (51%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2018-11-01 Data Encryption State: encrypted Repair imei... Checking modem version. Reading data. Be patient! Do NOT disconnect the phone! Repair imei failed. Finished at local time: [02.25.19 14:51:02] WorkID: 53XXXx |
