Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 03-30-2016, 10:43   #31 (permalink)
eivelice's Avatar
Member: 388962
Sonork: 100.1637202
Thanks Meter: 263
[Direct Unlock started]
You have 1 backup created for this phone in the past 12 hours. Skipping backup process.
Checking ports
For unlock, a DIAG mode serial must be present.
Searching for ports
Waiting for diag serial port to appear...
Please make sure 'Port Check Test' is enabled on the phone!
How to enable 'Port Check Test' or 'DIAG port' on your LG phone:
There are many different ways to enable this option, but not all of them will work on all phones. Try them out one-by-one
Dial in the following codes on your phone (without pressing call). If the code works a hidden menu will apear. Find the option 'Port Check Test', and set it to 'Enabled'. It is usually in the top menu or in the 'SVC Menu' submenu.
277634#*#
3845#*631#
*#546368#*631#
In case you can not get to the hidden menu, or the hidden menu does not contain the option 'Port Check Test', try Factory Reset on the phone.
DIAG mode serial found.
Unlocking
Phone IMEI is correct.: 35838706sssssss
Unlocked.
Restarting phone...
Finished successfully.
Finished at local time: [03.30.16 17:41:25]
WorkID: 10013301
have tried 3 times
t-mobile lg h631
but still is asking for unlock of unlock app by tmobile.
anything i can do?
Old 03-30-2016, 11:10   #32 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 23,706
reply
Dear Sir,
in some case after the factory reset you can find the port check in a secret menu, it is worth to try it.
Best regards
Nicole
Originally Posted by stinky180 View Post
Can't unlock LG Optimus F3 P659 because i can't find Port Check Test in secret menu. SVC menu isn't there too. Any advice?
Old 04-03-2016, 02:20   #33 (permalink)
Member: 1836541
Thanks Meter: 92
Chimeratool can add readinfor all model lg with downloadmod?
Old 04-04-2016, 14:13   #34 (permalink)
Member: 1787203
reply
Dear Sir,
sorry, not so clear for me. Please specify what function do you mean under the mentioned function, because at the moment ReadInfo function supported on the all supported LG model.
Best regards
Nicole
Old 04-15-2016, 20:30   #35 (permalink)
Member: 2364437
Thanks Meter: 4
I have an LG-V497 Tablet here that I am looking to unlock. My question is, if there isn't a phone dialer, how do you enter the code to get to the Port Check Test option?
Old 04-18-2016, 11:03   #36 (permalink)
Member: 1787203
reply
Dear Sir,
thank you for your message, at the moment it is under development, now you can not unlock the mentioned model with the chimeratool.
Best regards
Nicole
The Following User Says Thank You to Chimera Tool For This Useful Post:
Old 04-29-2016, 20:25   #37 (permalink)
Jazz's Avatar
Member: 219362
Thanks Meter: 31
Hi just wondering if we will be getting a FRP reset for the Lg?
Old 05-02-2016, 09:31   #38 (permalink)
Member: 1787203
reply
Dear Sir,
it is an planed function, but we can not write you any exact date when can we add it.
We will add it as soon as possible.
Best regards
Nicole
Old 05-14-2016, 05:50   #39 (permalink)
Member: 1556436
Thanks Meter: 65
Chimera team why cant you guys support even a single lg japan model? like lgl24,lgv31,lgv32 etc, even after i have summited some of their info throw development support, any solution or team that does not support japan variant models are not serious because its a big market in mobile community.
Old 05-17-2016, 10:18   #40 (permalink)
Member: 1787203
reply
Dear Sir,
We can see you (and others) have run development support for LG-L24 and LG-V31, but none of you have succeeded to enable the 'Port Check Test' option, or if you did, then the protocol did not open up we need for unlocking. This means even if we added this model you most likely could not unlock them.
Please make sure to follow the instructions you see in development support on how to enable 'Port Check Test' and re-run the development support again if you succeeded.
Since currently only direct unlock is of value to users, if we have no evidence that it will work for a model, we do not release it.
Best regards
Nicole
Old 05-27-2016, 15:43   #41 (permalink)
Arafat Mashaka's Avatar
Member: 750759
Sonork: 75101010
Thanks Meter: 169
i have LG g3 i enable the port but nothing change in software it doesn't event asked me to install driver i need help please
Old 05-27-2016, 15:52   #42 (permalink)
Member: 750759
Sonork: 75101010
Thanks Meter: 169
Now i succeed buy installing Lg usb driver
Chimera Mobile Phone Utility version: 10.26.1631 @ 2016-05-27
Printing phone history
Network Backup / Restore
5/27/2016
2:49:58
PM
5/27/2016
2:36:48
PM
Direct Unlock
5/27/2016
2:24:23
PM
Direct Unlock
5/27/2016
2:15:59
PM
Direct Unlock
5/27/2016
2:05:01
PM
Checking ports
Searching for ports
277634#*#
3845#*852#
*#546368#*852#
Unlocking
Phone IMEI is correct.: 354608062620010
Unlocked.
Restarting phone...
Finished at local time: [05.27.16 16:51:06]
WorkID: 11113975
Old 05-27-2016, 16:18   #43 (permalink)
Member: 750759
Sonork: 75101010
Thanks Meter: 169
Add support for lg E973 Direct unlock
5/27/2016
3:15:18
PM
5/27/2016
3:07:32
PM
Direct Unlock
5/26/2016
6:51:15
AM
Direct Unlock
5/25/2016
9:53:38
AM
Direct Unlock
5/25/2016
8:26:03
AM
Before this procedure it is recommended to create an EFS backup. Do you want to create a backup?
Backup skipped.
Checking ports
Searching for ports
277634#*#
3845#*973#
*#546368#*973#
Unlocking
Protocol is not supported.
Finished at local time: [05.27.16 17:16:25]
WorkID: 11114660
info
[Get info started]
Gathering information
Model name: LG-E973
Model firendly name: LG Optimus G (LG-E973)
Android Version: 4.0.4
Firmware Compilation Date: Nov 26 2012
Firmware Compilation Time: 13:22:14
Firmware Release Date: Oct 01 2012
Firmware Release Time: 03:00:00
'Port Check Test' is disabled.
IMEI: 354034051183672
SIM card state: PERSO_LOCKED
Properties:
Target country: CA
Target operator: BELL
Board type: gee
RIL version: Qualcomm RIL 1.0
HW Revision: rev_12
Factory version: LGE973AT-00-V10h-BLM-CA-DEC-03-2012+0
Finished at local time: [05.27.16 17:18:32]
WorkID: 11114724
Old 05-27-2016, 16:37   #44 (permalink)
Member: 1787203
reply
Dear Sir,
thank you for your feedback, my developer colleague added it to the priority projects, I hope shortly it will be solved.
Best regards
Nicole
5/27/2016
3:15:18
PM
5/27/2016
3:07:32
PM
Direct Unlock
5/26/2016
6:51:15
AM
Direct Unlock
5/25/2016
9:53:38
AM
Direct Unlock
5/25/2016
8:26:03
AM
Backup skipped.
Checking ports
Searching for ports
277634#*#
3845#*973#
*#546368#*973#
Unlocking
WorkID: 11114660
info
[Get info started]
Model name: LG-E973
Properties:
Target country: CA
Board type: gee
HW Revision: rev_12
WorkID: 11114724
Old 06-15-2016, 10:52   #45 (permalink)
Member: 2454980
Repair IMEI - LG D802:
Modem port found
IMEI Repair
Page generated in 0.28341 seconds with 8 queries
