07-10-2018, 15:18 | #1 (permalink) |
Freak Poster Join Date: Jun 2009
Member: 1059059 Status: Offline Thanks Meter: 18 | Lg k4 2017 m160 imei repair failled How to solve Thanks in advance [IMEI Repair started] Safe IMEI re-write check Safe IMEI re-write not possible. Need normal IMEI re-write method. Creating EFS backup... Waiting for serial port to appear... Trying to boot the phone into download mode... Waiting for download mode serial port to appear... If the device is stuck in dowload mode, remove the battery to reset the device.  EFS Backup failed. Proceed at your own risk. Press 'OK' to continue, and 'Cancel' to abort process! Checking ports For IMEI repair, a DIAG mode serial and a Modem port must be present. Searching for ports Waiting for diag serial port to appear...  Please make sure 'Port Check Test' is enabled on the phone! How to enable 'Port Check Test' or 'DIAG port' on your LG phone: There are many different ways to enable this option, but not all of them will work on all phones. Try them out one-by-one  Dial in the following codes on your phone (without pressing call). If the code works a hidden menu will appear. Find the option 'Port Check Test', and set it to 'Enabled'. It is usually in the top menu or in the 'SVC Menu' submenu. 277634#*# 3845#*160# *#546368#*160# In case you cannot get to the hidden menu, or the hidden menu does not contain the option 'Port Check Test', try Factory Reset on the phone. DIAG mode serial found. Modem port found Waiting for ADB connection.Be patient! Do NOT disconnect the phone! IMEI Repair Protocol error. Finished at local time: [07.10.18 16:15:11] WorkID: 40563085 |
The Following User Says Thank You to dimarog For This Useful Post: |
07-11-2018, 15:17 | #4 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,723 | reply Hi, my colleague checked that case. When He see the problem comes from the security side. We are working on the problem, I hope we can fix is shortly. At the moment the process can not be done on that exact device. Really sorry for the inconveniences. Best regards Nicole Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
07-11-2018, 18:04 | #5 (permalink) | |
Member: 1059059 Status: Offline Thanks Meter: 18 | Quote:
Thanks for the reply | |
07-12-2018, 11:45 | #6 (permalink) | |
I'il be warned | |
