12-11-2018, 12:40 | #1 (permalink) |
Junior Member Join Date: Sep 2012
Member: 1808376 Status: Offline Thanks Meter: 0 | LG M160 protocol error Someone could help me please? Here we have the log: IMEI Repair Safe IMEI re-write check Safe IMEI re-write not possible. Need normal IMEI re-write method. Before this procedure, it is recommended to create an EFS backup. Do you want to create a backup? Backup skipped. Checking ports For IMEI repair, a DIAG mode serial and a Modem port must be present. Searching for ports Waiting for diag serial port to appear... Please make sure Port Check Test is enabled on the phone! DIAG mode serial found. Modem port found IMEI Repair Protocol error. Finished at local time: [12.11.18 12:33:14] WorkID: 49048617 |
