05-19-2018, 12:24 | #1 (permalink) |
No Life Poster Join Date: Jul 2014 Location: EARTH
Member: 2221849 Status: Offline Sonork: offline Thanks Meter: 279 | Lg vs500pp development support Code: Chimera Mobile Phone Utility version: 17.50.1419 @ 2018-05-19 [Development Support started. Thank you for your help!] Processing... Android Version: 6.0.1 Getting port information... Protocol test. #1 No LG modem ports found... waiting for one port to appear. No LG modem ports found... waiting for one port to appear. Protocol test. #5 Waiting for serial port to appear...  Please set the phone into download mode manually. Unplug the phone from USB. Turn off the phone. Press and hold 'volume up'. Replug the device to USB while holding 'volume up'. Waiting for download mode serial port to appear... If the device is stuck in dowload mode, remove the battery to reset the device.  Please enable 'Port Check Test'. If enabled, run the development support again. Thank you! How to enable 'Port Check Test' or 'DIAG port' on your LG phone: There are many different ways to enable this option, but not all of them will work on all phones. Try them out one-by-one  Dial in the following codes on your phone (without pressing call). If the code works a hidden menu will appear. Find the option 'Port Check Test', and set it to 'Enabled'. It is usually in the top menu or in the 'SVC Menu' submenu. 277634#*# 3845#*<numbers in model name here># *#546368#*<numbers in model name here># In case you cannot get to the hidden menu, or the hidden menu does not contain the option 'Port Check Test', try Factory Reset on the phone. Process finished. Thank you for your support! Finished successfully. Finished at local time: [05.19.18 13:14:45] WorkID: 38001288 |
05-19-2018, 13:05 | #3 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, step by step, thanks for your feedback bro... Best Regards Shensohau |
The Following User Says Thank You to Shensohau For This Useful Post: |
05-22-2018, 13:46 | #4 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,756 | reply Hi, thank you for the development support process. It is really big help to our colleagues. We will add the model as soon as possible. Best regards Nicole |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
