09-13-2019, 07:30 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: cox's bazar bangladesh
Member: 1453066 Status: Offline Thanks Meter: 75 | patchcert Successfully finished but not network Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N935F Sales Code: XID Country Code: INDONESIA Timezone: Asia/Dhaka Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Wed Nov 14 15:52:37 KST 2018 PDA Version: N935FXXS4BRK2 [november 2018, rev2] Phone Version: N935FXXU4BRK2 [november 2018, rev2] CSC Version: N935FOLE4BRK2 [november 2018, rev2] Product Code: XID HIDSw Version: N935FXXS4BRK2/N935FOLE4BRK2/N935FXXU4BRK2/N935FXXS4BRK2 Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: RF8JB164VLW Imei: 352161045555558 Unique Number: CE10171A7CAD493801 Connections: AT,MTP Battery Status: 3.86V (55%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2018-11-01 Data Encryption State: unencrypted Preparing... Checking current patchcert. Checking modem. Checking root. The phone is rooted by: 3.14:EFTSU Checking boot image. Be patient! Do NOT disconnect the phone! Could not read the boot image for analysis. Maybe the root cause the issue (3.14:EFTSU). Selinux could cause problems. If the patchcert does not work, try another root solution. Reading data... Checking modem version. Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... The operation is in progress. Be patient! Do NOT disconnect the phone! After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [09.13.19 11:48:52] WorkID: 73006929 But no network |
09-13-2019, 09:35 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,734 | reply Hi, 1. re-flash your device 2. root it with magiskroot 3. start repair imei or write cert again 4. finally start patch cert process again Best regards Nicole Quote:
