03-03-2018, 11:17 | #1 (permalink) |
Freak Poster Join Date: May 2015 Location: Pakistan
Member: 2401943 Status: Offline Thanks Meter: 182 | N920C S4 modem File Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N920C Sales Code: XSG Country Code: UAE Timezone: Android Version: 7.0 [NRD90M] Build Date: Wed Jan 3 16:51:11 KST 2018 PDA Version: N920CXXS4CRA1 [january 2018, rev1] Phone Version: N920CXXU4CRA1 [january 2018, rev1] CSC Version: N920COJV4CRA1 [january 2018, rev1] Product Code: XSG HIDSw Version: N920CXXS4CRA1/N920COJV4CRA1/N920CXXU4CRA1/N920CXXS4CRA1 Board Platform: EXYNOS5 Modem Platform: SHANNON333 Serial Number: RF8H701CR5E Imei: Unique Number: 041604B17B670302 Connections: AT,MTP Battery Status: 3.91V (58%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 1 Security Patch: 2018-01-01 Data Encryption State: unsupported Reading cert... Searching serial port. Be patient! Do NOT disconnect the phone! Serial port found on COM40 Reading data. Be patient! Do NOT disconnect the phone! Inappropriate modem version. Try using an older modem. WARNING! You only have to flash the modem.bin from the firmware! Read cert failed. Finished at local time: [03.03.18 15:06:24] WorkID: 34215121 |
04-09-2018, 12:06 | #3 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,741 | When you need some instruction hos can you flash the modem.bin: 1. Choose the firmware under the firmware update. 2. Here you can find the "options" button, please press it. 3. Choose the "File Filter for Flashing Process" option and click on the "ok" button. 4. process will be started and you will get a pop up window, where you can choose the files of the firmware what you want to flash into the device. 5. process will be finished. Best regards: Nicole |
