Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 05-28-2019, 23:46   #1 (permalink)
Member: 2532441
Thanks Meter: 30
Arrow Note 8 android 9 bit 6 repair+patch 100%+fix hard reset+fix kg prenormal
NOTE 8 ANDROID 9 BIT 6 FULL REPAIR + PATCH 100% ... FIX HARD RESET 100%, FIX KG PRENORNAL OFF PERMANENT, AFTER HARD RESET FULL SIGNAL 100%, "SECURITYLOGAGENT" REMOVE PERMANENT 100% DOES NOT RETURN NOR WITH HARD RESET THE NOTIFICATION! 100%
IT IS NOT PRE-ROOT
http://www.youtube.com/watch?v=m-j--LJYOd0
Patch certificate started
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-N950F
Sales Code: ARO
Country Code: Argentina
Timezone: America/Argentina/Buenos_Aires
Android Version: 9 [PPR1.180610.011] [SDK 28]
Build Date: Fri Apr 26 16:32:13 KST 2019
PDA Version: N950FXXU6DSD5 [april 2019, rev5]
Phone Version: N950FXXU6DSD3 [april 2019, rev3]
CSC Version: N950FOXM6DSD5 [april 2019, rev5]
Product Code: ARO
HIDSw Version: N950FXXU6DSD5/N950FOXM6DSD5/N950FXXU6DSD3/N950FXXU6DSD5
Board Platform: EXYNOS5
Modem Platform: SHANNON355
Serial Number: R28K22XBBNV
Imei: 353517092805197
Unique Number: CE12171CC8D9CE13017E
Connections: AT,MTP
Battery Status: 4.14V (82%)
Network Type: GSM
SIM Status: ABSENT
Multisim Config: SS
Knox Version: v30
Warranty Bit: 0
Security Patch: 2019-05-01
Data Encryption State: unencrypted
Preparing...
Checking current patchcert.
Checking modem.
Checking root.
The phone is rooted by: 18.2-0204d053:MAGISKSU
Checking boot image. Be patient! Do NOT disconnect the phone!
The knox is still valid. Because of the boot patch the warranty will void.
Writing boot image.
Restarting phone.
Waiting for ADB connection. Be patient! Do NOT disconnect the phone!
Reading data...
Checking modem version.
Reading data. Be patient! Do NOT disconnect the phone!
Patching certificate...
After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds.
You can check the status of the imei using: *#0011#
The patchcert can be removed by repeating the process.
If a new firmware is used, the patchcert process must be repeated.
Succeeded.
Successfully finished.
Finished at local time: [05.28.19 16:38:14]
WorkID: 61030182
The Following 2 Users Say Thank You to zam_aybar For This Useful Post:
Old 05-29-2019, 09:55   #2 (permalink)
Member: 2765424
Thanks Meter: 1,039
how to fix
kg state: prenormal fix
Old 05-29-2019, 10:34   #3 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 23,778
reply
KG lock->KnoxGuard unlock. Please start Knoxguard Unlock process
Originally Posted by taimur-ahmad View Post
how to fix
Old 05-30-2019, 18:59   #4 (permalink)
Member: 2575029
Thanks Meter: 122
how root n950f u6?
after write twrp phone reboot logo
Old 05-30-2019, 20:13   #5 (permalink)
Member: 2575029
Thanks Meter: 122
rooted this phone.
KnoxGuard unlock but after reboot back to personal.
and Only official released binaries are allowed to be flashed.
Chimera Mobile Phone Utility version: 21.25.1302 @ ۲۰۱۹-۰۵-۳۰
Printing phone history
Patch Certificate
30/05/2019
06:27:16
ب.ظ
Knoxguard Unlock
30/05/2019
05:48:25
ب.ظ
Rmm Unlock
30/05/2019
05:43:18
ب.ظ
Patch Certificate
15/05/2019
07:51:06
ب.ظ
Repair IMEI
15/05/2019
07:48:57
ب.ظ
Knox Guard Unlock started
Model: SM-N950F
Sales Code: THR
Country Code: IRAN
Timezone: Asia/Tehran
Product Code: THR
Serial Number: R38JA07F7QX
Imei: 862887013201469
Unique Number: 988A5C434C4B30454530
Connections: AT,MTP
Battery Status: 3.78V (33%)
Network Type: GSM
SIM Status: LOADED,ABSENT
Multisim Config: DSDS
Knox Version: v30
Warranty Bit: 1
Data Encryption State: encrypted
Unlocking KnoxGuard...
The operation is in progress. Be patient! Do NOT disconnect the phone!
Current state: Prenormal
New state: Completed
Succeeded!
Finished at local time: [۰۵.۳۰.۱۹ ۲۳:۲۲:۳۱]
WorkID: 61242176
Old 05-30-2019, 20:38   #6 (permalink)
Member: 2575029
Thanks Meter: 122
after root again unlock kg but after write boot with chimera
install with twrp byass rmm.
Knoxguard Unlock
30/05/2019
07:27:45
ب.ظ
Knoxguard Unlock
30/05/2019
07:19:46
ب.ظ
Patch Certificate
30/05/2019
07:05:51
ب.ظ
Knoxguard Unlock
30/05/2019
06:57:23
ب.ظ
Rmm Unlock
30/05/2019
06:54:55
ب.ظ
Model: SM-N950F
Sales Code: THR
Country Code: IRAN
Product Code: THR
Connections: AT,MTP
Battery Status: 3.74V (28%)
Network Type: GSM
Knox Version: v30
Warranty Bit: 0
Preparing...
Checking modem.
Checking root.
The phone is rooted by: 18.1:MAGISKSU (topjohnwu)
Writing boot image.
Restarting phone.
Unable to establish ADB connection.
Finished at local time: [۰۵.۳۱.۱۹ ۰۰:۰۳:۴۷]
WorkID: 61246713
Old 05-31-2019, 22:21   #7 (permalink)
Member: 2562183
Sonork: Adnan
Thanks Meter: 2
please share root files
Old 06-03-2019, 18:35   #8 (permalink)
Member: 2908893
i did it on N950f Android 9 and was successful but imei status NG didnt have signal so i have to go back to 8 but overheat problems and battery drain appear again
Old 07-11-2019, 14:49   #9 (permalink)
Member: 1775687
Sonork: sman
Thanks Meter: 25
Please i need the root file N950f u6 pie any links
Old 07-11-2019, 15:01   #10 (permalink)
Member: 1143651
Sonork: REYMORA
Thanks Meter: 2
S9
Cual es la solucion definitiva para el rmm?
Old 07-11-2019, 15:52   #11 (permalink)
Member: 2346548
Thanks Meter: 36
everything is ok but after hard reset client back with phone
any solution to disable kg even after hard reset?
Old 07-12-2019, 21:18   #12 (permalink)
Member: 2575029
Thanks Meter: 122
BEFORE WRITE MAGISK FLASH RMM_Bypass_v3_corsicanu
Page generated in 2.20139 seconds with 8 queries
