05-27-2018, 00:27 | #1 (permalink) |
Insane Poster Join Date: Dec 2013 Location: GSM WORLD
Member: 2096181 Status: Offline Thanks Meter: 15 | P9 Lite Problem Identify Chimera Versión de la Mobile Phone Utility: 17.57.0905 @ 2018-05-26 Printing phone history Get Info 26/05/2018 11:23:08 p. m. FRP Remove 26/05/2018 11:19:50 p. m. [Repairing IMEI(s)...] Searching for Manufacture port... Testing connection... Checking IMEI(s)... Old IMEI 1: 355646042340340 New IMEI 1: 869396029814417 Old IMEI 2: 355646042340340 New IMEI 2: 869396029814425 Authenticating... This may take a while. Be patient! Do NOT disconnect the phone! Identifying... This may take a while. Be patient! Do NOT disconnect the phone! Failed to send identification credentials to the device Retry 2/5 Failed to send identification credentials to the device Retry 3/5 Failed to send identification credentials to the device Retry 4/5 Failed to send identification credentials to the device Retry 5/5 Failed to send identification credentials to the device Authentication with the device failed. Finished at local time: [05.26.18 18:25:25] WorkID: 38391653 |
05-27-2018, 13:00 | #2 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, I recommend you install a clean system, for Huawei drivers please only install lastest version of hisuite, but desactivate auto detect devices when plug it and auto open program too, then retry all process you will be ok... Best Regards Chimeratool Team |
05-28-2018, 22:58 | #3 (permalink) |
Member: 2096181 Status: Offline Thanks Meter: 15 | The drivers are not why others that have been modified by another tool pass the process correctly ... They even come out with Furiuos Gold is a problem in the module that had already been corrected previously I need a solution! |
