Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 05-15-2020, 18:04   #1 (permalink)
Member: 2575029
Thanks Meter: 122
patch cert a750f u4 os10
patch cert done
Chimera Mobile Phone Utility version: 24.79.1106 @ 2020-05-15
Printing phone history
Patch Certificate
2020-mm-15
4:56:45
PM
Patch Certificate
2020-mm-15
4:53:26
PM
Patch Certificate
2019-mm-23
4:49:32
PM
Repair IMEI
2019-mm-23
4:24:40
PM
Patch certificate started
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-A750F
Sales Code: THR
Country Code: IRAN
Timezone: Asia/Tehran
Android Version: 10 [QP1A.190711.020] [SDK 29]
Build Date: Fri Mar 27 23:00:10 KST 2020
PDA Version: A750FXXU4CTC8 [march 2020, rev8]
Phone Version: A750FNXXU4CTBB [february 2020, revB]
CSC Version: A750FOJM4CTC8 [march 2020, rev8]
Product Code: THR
HIDSw Version: A750FXXU4CTC8/A750FOJM4CTC8/A750FNXXU4CTBB/A750FXXU4CTC8
Board Platform: UNIVERSAL7885
Modem Platform: SHANNON327
Serial Number: RF8M10L86TD
Imei: 86
Unique Number: CDU00EA5BC0A0C5
Connections: AT,MTP
Network Type: GSM
SIM Status: ABSENT,ABSENT
Multisim Config: DSDS
Knox Version: v30
Warranty Bit: 1
Security Patch: 2020-03-01
Preparing...
Checking root access.
The phone is rooted by: 20.4:MAGISKSU
Reading data...
The operation is in progress. Be patient! Do NOT disconnect the phone!
Patching certificate...
About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds.
You can check the status of the imei using: *#0011#
The patchcert can be removed by repeating the process.
If a new firmware is used, the patchcert process must be repeated.
Successfully finished.
Finished at local time: [05.15.20 21:32:42]
WorkID: 95361917
The Following 2 Users Say Thank You to gsm-ok For This Useful Post:
Old 04-26-2021, 03:06   #2 (permalink)
Member: 2358876
Thanks Meter: 78
HOW didi you root the phone??? APRIL 2021?
Originally Posted by gsm-ok View Post
patch cert done
Patch Certificate
2020-mm-15
4:56:45
PM
Patch Certificate
2020-mm-15
4:53:26
PM
Patch Certificate
2019-mm-23
4:49:32
PM
Repair IMEI
2019-mm-23
4:24:40
PM
Model: SM-A750F
Sales Code: THR
Country Code: IRAN
Product Code: THR
Imei: 86
Connections: AT,MTP
Network Type: GSM
Knox Version: v30
Warranty Bit: 1
Preparing...
Reading data...
WorkID: 95361917
RMM State: Prenormal
OEM OFF
KG status OFF (checking)
Custom Binary OFFICIAL
I CANT Flash the TWRP or Patched boot
Problem " Binary not allowed bla blah
Which ROOT method work
My BIG question is how to turn off the RMM state: Prenormal??? Dev OEM option is ON........OEM is ON
Page generated in 0.13491 seconds with 8 queries
