01-15-2019, 18:37 | #1 (permalink) | |
Freak Poster Join Date: Jun 2006
Member: 296765 Status: Offline Thanks Meter: 10 | Problem Read Codes Samsung G935a I have one Problem with this PHone I read the Codes by Button Read Codes Online but with i enter de code in the Phone the Phone Accept the Code but the phone restar Only Said Invalid Sim. This is the Log Quote:
01-15-2019, 21:41 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | The problem is that the READ CODES ONLINE method can not guarantee the Freeze code , just the network unlock code. You can try with this modem: CP_G935TUVS8CRJ1_CP10947954_CL14365146_QB20116563_ REV02_user_low_ship_MULTI_CERT.tar.rar |
01-15-2019, 23:41 | #3 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, for read codes please use this ENG Modem version: G935AUCS4_ENG MODEM... look for that, flash device read codes and you will be ok... Best Regards Shensohau |
01-16-2019, 14:22 | #5 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Online Thanks Meter: 23,752 | reply We deduce only 1x the credits for the same device, so just try again. Before it, please install chimera drivers on your computer. https://chimeratool.com/en/docs/drivers Best regards Nicole |
01-17-2019, 16:47 | #7 (permalink) | |
Member: 296765 Status: Offline Thanks Meter: 10 | Quote:
The Codes Are Wrong. Whats need i Do? Thanks | |
01-18-2019, 05:43 | #8 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 952912 Status: Offline Thanks Meter: 142 | Those code numbers (00000000 freeze and 01234567 others) are the default codes for sprint and some tmobile, since they are not unlocked by code. If flashed to ATT firmware, it will behave like ATT device, ask for code, check it matches these default codes, and because it matches, it says successful. It will still be locked, however, because the locktype is different Is it possible it is a sprint or tmobile model originally, which was flashed with ATT firmware? It seems to fit the criteria. |
