03-13-2017, 16:20 | #1 (permalink) |
Junior Member Join Date: Jan 2008
Member: 689394 Status: Offline Thanks Meter: 0 | remove FRP A310F My firmware is 6.0.1 A310FXXU2BPH8_A310FOXX2BPI8_A310FXXU2BPG2_HOME.tar I can't remove frp [Reset FRP lock started] Selected model: SM-A310F Checking boot image... Present. Flashing boot image... Flashing boot image. After reboot, if the boot process get stuck, you can install a stock firmware. Flashing firmware... Waiting for download mode. Connecting. Reading PIT. Checking firmware compatibility. RP SWREV: B:2 K:0 S:0 The firmware version is compatible. Flashing boot.img Restarting phone. Waiting for device. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Processing... Unable to reset FRP. Finished at local time: [03.13.17 16:16:49] WorkID: 18900890 how can I downgrader my phone please for remove FRP thank you |
03-13-2017, 16:23 | #2 (permalink) |
Member: 689394 Status: Offline Thanks Meter: 0 | Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A310F Sales Code: XEH Country Code: Hungary Timezone: Europe/Paris Android Version: 6.0.1 [MMB29K] Build Date: Sat Aug 27 13:28:04 KST 2016 PDA Version: A310FXXU2BPH8 [august 2016, rev8] CSC Version: A310FOXX2BPI8 [september 2016, rev8] Board Platform: EXYNOS5 Serial Number: R28H71JLP8Z Battery Status: 4.12V (72%) Network Type: UNKNOWN Knox Version: v30 Warranty Bit: 0 Security Patch: 2016-09-01 Finished successfully. Finished at local time: [03.13.17 16:21:00] WorkID: 18901300 |
03-13-2017, 16:50 | #3 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
To remove the FRP please use this firmware version: SM-A310FXXUA2APC1 03/2016 SM-310FXXUA2APG1 07/2016 It is important that you use a firmware with binary: 2 as you already have and use a firmware with letter A to obtain a satisfactory result. Firmwares here: https://samsung-firmware.org/downloa...A310FOXY2APC5/ | |
03-13-2017, 17:50 | #4 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,783 | reply Dear User, You have to use an older released 6.0.1 android version. You can downgrade it in download mode with the Firmware Update function. Best Regards Chimera Team Quote:
04-25-2017, 18:14 | #6 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | In general for the model A310F there are the following firmwares with different binaries (3/2/1) A310FXXU3BQC2 6.0.1 03.03.2017 A310FXXU2BQAA 6.0.1 23.01.2017 A310FXXU2APDC 5.1.1 27.04.2016 A310FXXU2APC5 5.1.1 29.03.2016 A310FXXU1AOL7 5.1.1 08.12.2015 The options that currently have chimera are the following: To remove the FRP you should use these firmwares: SM-A310FXXUA2APC1 03/2016 SM-A310FXXUA2APG1 07/2016 It depends on the firmware you have in your phone and the binary file, you can degrade or not but always respecting the Bit: (3/2/1) In case you have Binary: 3 then you could flash with a binary combination file: 3 and in normal mode do the frp with chimera. What firmware do you have on your phone? |
04-25-2017, 18:37 | #8 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Dear user! It would help a little more information about the fimware version with some detail to be able to help you. For example: A310FXXU3XXXX 6.0.1 03.03.2017 To know what firmware you have in your phone, put in recovery mode and in the second line will see its firmware. |
04-26-2017, 07:38 | #9 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | i write this version AP_A310FXXU2BPG6_CL8581216_QB10246132_REV00_user_l ow_ship.tar BL_A310FXXU2BPG6_CL8581216_QB10246132_REV00_user_l ow_ship.tar CP_A310FXXU2BPG6_CL255697_QB4832211_SIGNED.tar CSC_OJV_A310FOJV2BPG2_CL8581216_QB10246132_REV00_u ser_low_ship.tar |
04-26-2017, 11:23 | #10 (permalink) | |
To remove the FRP you should use these firmwares: SM-A310FXXUA2APC1 03/2016 SM-A310FXXUA2APG1 07/2016 | |
04-26-2017, 12:24 | #12 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Here Sir: https://www.androidfilehost.com/?w=s...e=files&page=3 Or on the official Sam Mobile website as well. You can download from chimera too. |
04-26-2017, 13:32 | #13 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Dear User! Your phone has: SW REV B: 2, K: 0, S: 0 1. Flash with Chimera with FW from support: A310FXXU2APD6_A310FVFG2APC2_A310FXXU2APC5_A310FXXU 2APD6_PRO 2. FRP SM-A310F-A310FXXU2APC1 (3/2016) 3. After switch on OEM UNLOCK in Developer Settings 4. Later from factory default 5. Flash FW what you need. ************************************************** *********************************** Another alternative: 1. -Download and flash the file through odin A310F https://firmware.gem-flash.com/index...e-info&id=7471 -This will enable adb. Run the command to bypass activation (Adb shell content insert --url content: // settings / secure --bind name: s: user_setup_complete --bind value: s: 1) - Turn on oem unlocking and reset. - Then, flash with the last firmware. |
04-26-2017, 13:44 | #14 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | <ID:0/059> Added!! <ID:0/059> Odin engine v(ID:3.1101).. <ID:0/059> File analysis.. <ID:0/059> SetupConnection.. <ID:0/059> Initialzation.. <ID:0/059> Get PIT for mapping.. <ID:0/059> Firmware update start.. <ID:0/059> SingleDownload. <ID:0/059> sboot.bin <ID:0/059> NAND Write Start!! <ID:0/059> boot.img <ID:0/059> RQT_CLOSE !! <ID:0/059> RES OK !! <ID:0/059> Removed!! <ID:0/059> Remain Port .... 0 <OSM> All threads completed. (succeed 1 / failed 0) <ID:0/009> Added!! |
