08-22-2019, 08:24 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | S7 Edge G935L patch cert problem after conver to Dual Sim Need help to repair Patch Cert on Custom Rom. My phone is G935L U2 8.0.0 i convert this phone to G935F U2 7.0 Rooted with Su2.82 patch Cert with chimera and successfully patched. but phone have no signal, not show airoplain mode after done patch, imei status is NG On single sim patch cert done and signal is fine. My WorkID: 70547824 Here is log Code: Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G935F Sales Code: BTU Country Code: UK & IRE Timezone: Asia/Karachi Android Version: 7.0 [NRD90M] [SDK 24] Build Date: Wed Jan 17 10:55:23 KST 2018 PDA Version: G935SXXU2DRAG [january 2018, revG] Phone Version: G935LKLU2ERI1 [september 2018, rev1] CSC Version: G935FOXA1DQJ3 [october 2017, rev3] Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: R39H30M02Z Imei: 35530907******* Battery Status: 3.87V (46%) Network Type: GSM SIM Status: ABSENT,READY Multisim Config: DSDS Knox Version: v00 Warranty Bit: 1 Security Patch: 2018-01-01 Data Encryption State: unencrypted Preparing... Checking current patchcert. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Previous patchcert successfully removed. Checking modem. Checking root. The phone is rooted by: 2.82:SUPERSU Checking boot image. Be patient! Do NOT disconnect the phone! Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... The operation is in progress. Be patient! Do NOT disconnect the phone! After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [08.22.19 12:15:50] WorkID: 70547824 |
08-22-2019, 16:21 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,752 | reply Dear User, Please reflash the device and root it again. Then use the IMEI repair and the mentioned Patch cert service. If you face the same problem as before, please let us know it. Best Regards Chimera Team Quote:
08-22-2019, 16:47 | #3 (permalink) | |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Quote:
sir i test 4 time with chimera and with other tools but the main Question is, is it possible to Patch CERT on Custom rom??? | |
08-26-2019, 09:43 | #5 (permalink) | |
Freak Poster Join Date: Jan 2008 Location: PAKISTAN Age: 38
Member: 689829 Status: Offline Sonork: 100.1651716 Thanks Meter: 102 | Quote:
in build.prop edit model to G935L then patch. Tested | |
The Following 3 Users Say Thank You to jaan_e_ahsan45 For This Useful Post: |
