10-21-2019, 14:45 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: Here
Member: 2102546 Status: Offline Thanks Meter: 480 | S8+ imei repair and patch cert done! Printing phone history Root/Unroot 2019-mm-21 11:48:48 AM Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G955F Sales Code: XSG Country Code: Kenya Timezone: Africa/Addis_Ababa Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Wed Oct 10 16:18:48 KST 2018 PDA Version: G955FXXU4CRJ5 [october 2018, rev5] Phone Version: G955FXXU4CRI9 [september 2018, rev9] CSC Version: G955FOXM4CRJ3 [october 2018, rev3] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: RF8KB0ZCELD Battery Status: 3.97V (66%) Network Type: GSM SIM Status: READY,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2018-10-01 Data Encryption State: encrypted Repair imei... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Repaired IMEI: 359049089542124 Repaired IMEI2: 359049089542132 If necessary, use the patch cert procedure. Succeeded. Successfully finished. Finished at local time: [10.21.19 15:03:43] WorkID: 76791766 ================================== Patch Cert Chimera Mobile Phone Utility version: 22.65.0616 @ 2019-10-21 Printing phone history Repair IMEI 2019-mm-21 12:02:28 PM Root/Unroot 2019-mm-21 11:48:48 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G955F Sales Code: XSG Country Code: Kenya Timezone: Africa/Addis_Ababa Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Wed Oct 10 16:18:48 KST 2018 PDA Version: G955FXXU4CRJ5 [october 2018, rev5] Phone Version: G955FXXU4CRI9 [september 2018, rev9] CSC Version: G955FOXM4CRJ3 [october 2018, rev3] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: RF8KB0ZCELD Imei: 359049089542124 Battery Status: 3.96V (66%) Network Type: GSM SIM Status: READY,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2018-10-01 Data Encryption State: encrypted Preparing... Checking current patchcert. Checking modem. Checking root. The phone is rooted by: Chimera SU v1.0 Checking boot image. Be patient! Do NOT disconnect the phone! Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... The operation is in progress. Be patient! Do NOT disconnect the phone! After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [10.21.19 15:07:03] WorkID: 76792024 BR, Baya |
The Following User Says Thank You to eyobaaa For This Useful Post: |
