08-24-2019, 07:01 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | S8 plus u5 imi repair patch done Code: Chimera Mobile Phone Utility version: 22.12.0817 @ 2019-08-23 Printing phone history Repair IMEI 2019-08-23 03:53:14 PM Rmm Unlock 2019-08-23 12:53:23 PM Knoxguard Unlock 2019-08-23 12:51:07 PM Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G955F Sales Code: XFV Country Code: Germany Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Jun 26 16:23:47 KST 2019 PDA Version: G955FXXU5DSFB [june 2019, revB] Phone Version: G955FXXU5ASF1 [june 2019, rev1] CSC Version: G955FOXM5DSFB [june 2019, revB] Product Code: DBT HIDSw Version: G955FXXU5DSFB/G955FOXM5DSFB/G955FXXU5ASF1/G955FXXU5DSFB Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: R58J50PK2WW Imei: 358792083803692 Unique Number: CE031713FBE498A70D Connections: AT,MTP Battery Status: 4.04V (85%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-07-01 Data Encryption State: unencrypted Repair imei... Checking modem version. Reading data. Be patient! Do NOT disconnect the phone! Repaired IMEI: 357656890099664 If necessary, use the patch cert procedure. Succeeded. Successfully finished. Finished at local time: [08.23.19 17:57:35] WorkID: 70708347 PATCH Code: Chimera Mobile Phone Utility version: 22.12.0817 @ 2019-08-23 Printing phone history Repair IMEI 2019-08-23 03:57:10 PM Repair IMEI 2019-08-23 03:53:14 PM Rmm Unlock 2019-08-23 12:53:23 PM Knoxguard Unlock 2019-08-23 12:51:07 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G955F Sales Code: XFV Country Code: Germany Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Jun 26 16:23:47 KST 2019 PDA Version: G955FXXU5DSFB [june 2019, revB] Phone Version: G955FXXU5ASF1 [june 2019, rev1] CSC Version: G955FOXM5DSFB [june 2019, revB] Product Code: DBT HIDSw Version: G955FXXU5DSFB/G955FOXM5DSFB/G955FXXU5ASF1/G955FXXU5DSFB Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: R58J50PK2WW Imei: 357656890099664 Unique Number: CE031713FBE498A70D Connections: AT,MTP Battery Status: 4.16V (90%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-07-01 Data Encryption State: unencrypted Preparing... Checking current patchcert. Checking modem. Checking root. The phone is rooted by: 19.4-736729f5:MAGISKSU Checking boot image. Be patient! Do NOT disconnect the phone! The knox is still valid. Because of the boot patch the warranty will void. Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... The operation is in progress. Be patient! Do NOT disconnect the phone! After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [08.23.19 18:20:25] WorkID: 70711321 |
The Following 2 Users Say Thank You to CHAUDHRAY ARSHAD For This Useful Post: |
01-28-2020, 15:36 | #7 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,755 | reply Hi, when I see from the logs you started lot of patch cert and imei repair process on your device. Please now re-flash your phone with complete stock firmware (just with stock firmware) and repeat the processes again. 1. imei repair 2. root 3. patch cert Best regards Nicole |
01-28-2020, 22:44 | #8 (permalink) | |
Member: 331337 Status: Offline Thanks Meter: 72 | Quote:
