11-19-2017, 10:45 | #1 (permalink) |
Junior Member Join Date: Jun 2010 Location: Poland
Member: 1315665 Status: Offline Thanks Meter: 0 | Samsung A510f FRP need help |
11-19-2017, 10:57 | #2 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Quote:
Mr gcceleghg all explained everything.... To remove the account from google or FRP you first have to know what firmware you currently have on your phone and for that you put your phone in recovery mode (Vol + - Home - Power) you can see in the second line that firmware you have Once you know which firmware it is very important to know which binary file you have to solve the FRP problem A510FXXU4BQC2 6.0.1 - Binary: 4 A510FXXS3BQA2 6.0.1 - Binary: 3 A510FXXS2BPG1 6.0.1 - Binary: 2 A510FXXU1AOL9 5.1.1 - Binary: 1 Process 1. Open Chimera 2. Put your phone in download mode 3. Once you know which firmware version you have and according to the above, when you choose the option of Reset FRP Lock - New, Chimera will show you the following options for the A510F: A510FDXXU1AOL5 12/2015 A510FDXXU1APG2 07/2016 A510FXXU1AOL7 12/2015 A510FXXU1APC2 03/2016 A510FXXU2APC2 03/2016 A510FXXU2APG1 07/2016 A510FXXU2APH3 08/2016 Then you should choose the same firmware option you have on your phone. Then the software will guide you on the different screens. If you have firmware like this: A510FXXU4CQH2 7.0 then degrade to version 6.0.1 First flash this firmware: A510FFXXU4BQC1 version 6.0.1 Once you have this firmware A510FFXXU4BQC1 then you can use the combination file or engineering to solve it. Follow these steps: 1. Download the combination file (Factory Combination) https://www.4shared.com/rar/e9Ua6a0j...A510FXXU4.html (Pass to decompress into the .rar) 2. Flash with Odin 3.11.1 on PDA 3. When you start the phone you will see a menu of engineering firmware 4. This firmware will open the adb communication of the phone with the software 5. Make sure that usb debugging is checked Connect the phone to chimera in NORMAL MODE and execute the option FRP Reset New (In normal mode) Once the FRP is finished, make sure that usb debugging and OEM unlock is checked and manually reset the phone from the menu. 6. Turn off the phone and put it in download mode. 7. Flash your phone with the latest version that previously had A510FFXXu4BQC1 and FRP: OFF http://forum.gsmhosting.com/vbb/f898...olved-2269959/ | |
The Following 4 Users Say Thank You to gile@gile For This Useful Post: |
