05-06-2020, 13:01 | #1 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Türkiye Age: 44
Member: 341207 Status: Offline Thanks Meter: 14 | samsung G570f patchcert ok imei repair ok bud signal not Printing phone history Repair IMEI 06.05.2020 11:51:14 Root/Unroot 05.05.2020 15:47:59 Knoxguard Remove 04.05.2020 14:14:05 Rmm Remove 04.05.2020 14:09:08 Get Info 04.05.2020 14:06:01 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G570F Sales Code: CAC Country Code: Central Asia Timezone: Europe/Istanbul Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Sat Jul 27 14:53:11 KST 2019 PDA Version: G570FXXS2CSG2 [july 2019, rev2] Phone Version: G570FXXS2CSG3 [july 2019, rev3] CSC Version: G570FOXE2CSG1 [july 2019, rev1] Product Code: CAC HIDSw Version: G570FXXS2CSG2/G570FOXE2CSG1/G570FXXS2CSG3/G570FXXS2CSG2 Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: R58J919KX7A Imei: 353449021842069 Unique Number: CQ3002A68E43684 Connections: AT,MTP Battery Status: 4.31V (100%) Network Type: GSM SIM Status: READY,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2019-08-01 Preparing... Checking root access. The phone is rooted by: 3.18:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [05.06.20 14:54:16] WorkID: 94592836 all ok but not registered on the network *^1100^ phone restar ??? |
05-06-2020, 16:05 | #3 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,725 | reply Dear User, Please update the device with the following firmware: PDA Version: G570FXXU2CSL2 [december 2019, rev2] then run the IMEI REPAIR + the PATCH CERT services on it. After that the network should be workable. Most of our users do work with the mentioned firmware, we do recommend to use it. Best Regards Sab Chimera Team Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
05-06-2020, 17:16 | #4 (permalink) |
Member: 341207 Status: Offline Thanks Meter: 14 | Chimera Mobile Phone Utility version: 24.70.1418 @ 2020-05-06 Printing phone history Patch Certificate 06.05.2020 16:00:34 Repair IMEI 06.05.2020 15:58:28 Patch Certificate 06.05.2020 12:06:54 Patch Certificate 06.05.2020 12:04:51 Network Factory Reset 06.05.2020 12:03:00 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G570F Sales Code: INS Country Code: India Timezone: Europe/Istanbul Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Sat Dec 14 00:32:53 KST 2019 PDA Version: G570FXXU2CSL2 [december 2019, rev2] Phone Version: G570FXXU2CSL1 [december 2019, rev1] CSC Version: G570FODD2CSL1 [december 2019, rev1] Product Code: INS HIDSw Version: G570FXXU2CSL2/G570FODD2CSL1/G570FXXU2CSL1/G570FXXU2CSL2 Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: R58J919KX7A Imei: 353449021842069 Unique Number: CQ3002A68E43684 Connections: AT,MTP Battery Status: 4.31V (100%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2019-12-01 Preparing... Checking root access. The phone is rooted by: 3.18:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [05.06.20 19:12:59] WorkID: 94614865 all ok but some problem not registered on the network |
05-06-2020, 20:31 | #5 (permalink) | |
Member: 341207 Status: Offline Thanks Meter: 14 | Quote:
imei repair ok after root patch cert all ok but not registered on the network where is the mistake what can I do ??? | |
05-07-2020, 12:02 | #7 (permalink) |
Member: 341207 Status: Offline Thanks Meter: 14 | I've been trying for a week I changed imei s and tried again everything is normal but not searching chimera imei repair ok patch cert ok not searching ? u2 g570f imei repair support ok but why not work ? |
05-07-2020, 12:34 | #8 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,725 | reply Hi, one more thing what you can try: 'The phone is rooted by: 3.18:EFTSU' Please root your device with magisk root instead of EFTSU. Best regards Nicole |
05-07-2020, 13:51 | #9 (permalink) |
Member: 341207 Status: Offline Thanks Meter: 14 | pda verıson ok G570FXXU2CSL2 after imei rpair egain change repair ok after root patch cert ok some problem how to solve cımera team ? z3x not work eft not work octoplus not work cıhımera not work how to solve |
05-08-2020, 01:16 | #10 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: America
Member: 138781 Status: Offline Thanks Meter: 850 | Quote:
The answer is simple. your problem is the root of eft. use original root magisk for twrp and it will solve your problem flash root twrp magisk patch chimera full | |
The Following 2 Users Say Thank You to cellcarcol For This Useful Post: |
05-08-2020, 18:08 | #11 (permalink) | |
Chimera Mobile Phone Utility version: 24.71.1209 @ 2020-05-08 Printing phone history Patch Certificate 08.05.2020 17:02:05 Patch Certificate 08.05.2020 17:01:38 Patch Certificate 08.05.2020 16:16:23 Patch Certificate 08.05.2020 16:09:13 Root/Unroot 08.05.2020 16:08:00 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G570F Sales Code: INS Country Code: India Timezone: Europe/Istanbul Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Sat Dec 14 00:32:53 KST 2019 PDA Version: G570FXXU2CSL2 [december 2019, rev2] Phone Version: G570FXXU2CSL1 [december 2019, rev1] CSC Version: G570FODD2CSL1 [december 2019, rev1] Product Code: INS HIDSw Version: G570FXXU2CSL2/G570FODD2CSL1/G570FXXU2CSL1/G570FXXU2CSL2 Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: R58J919KX7A Imei: 351912066636730 Unique Number: CQ3002A68E43684 Connections: AT,MTP Battery Status: 3.93V (55%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2019-12-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [05.08.20 20:03:31] WorkID: 94774750 all ok but not sıgnal | |
