11-25-2016, 14:53 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: India [UNKNOWN]
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | samsung g570f reset frp lock ERROR Chimera Mobile Phone Utility version: 12.10.1702 @ 2016-11-25 Printing phone history Reset FRP Lock 11/25/2016 12:05:38 PM [Reset FRP lock started] Selected model: SM-G570F Checking boot image... Present. Flashing boot image... Flashing boot image. After reboot, if the boot process get stuck, you can install a stock firmware. Flashing firmware... Waiting for download mode. Connecting. Reading PIT. Checking firmware compatibility. RP SWREV: B:1 K:0 S:0 The firmware version is compatible. Flashing boot.img Restarting phone. Waiting for device. Be patient! Do NOT disconnect the phone! Device unavailable. Finished at local time: WorkID: 15361512 after phone restart with this process stuck on logo |
11-25-2016, 15:13 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Supported features SM-G570F ✓ SW Change ✓ Info ✓ Root/Unroot ✓ Restore / Store backup ✓ Reset FRP Lock ✓ Firmware Compatibility This model is very new Sir. First try hard reset and check if the problem solved. |
11-25-2016, 15:22 | #4 (permalink) |
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | but my set is hang on logo and i try to flash but odin cant flash custom binary hidden blocked by frp lock in screen show when i flash <ID:0/023> Added!! <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Binary Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/023> Odin engine v(ID:3.1100).. <ID:0/023> File analysis.. <ID:0/023> SetupConnection.. <ID:0/023> Initialzation.. <ID:0/023> Set PIT file.. <ID:0/023> DO NOT TURN OFF TARGET!! <ID:0/023> Get PIT for mapping.. <ID:0/023> Firmware update start.. <ID:0/023> SingleDownload. <ID:0/023> sboot.bin <ID:0/023> NAND Write Start!! <ID:0/023> param.bin <ID:0/023> cm.bin <ID:0/023> boot.img <ID:0/023> recovery.img <ID:0/023> system.img <ID:0/023> userdata.img <ID:0/023> modem.bin <ID:0/023> Transmission Complete.. <ID:0/023> Now Writing.. Please wait about 2 minutes <ID:0/023> Receive Response from boot-loader <ID:0/023> cache.img <ID:0/023> hidden.img <ID:0/023> RQT_CLOSE !! <ID:0/023> <ID:0/023> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) |
11-25-2016, 15:29 | #5 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Not flash with Odin. Flash with Kies3 or Smart Switch using Register Numer (s/n) or Chimera too Choosing the latest version and you can leave the phone frozen in the logo. To solve the FRP, make the option of the previous post. |
11-26-2016, 10:46 | #6 (permalink) | |
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | Quote:
and kies 3 also not supported for update how to recover phone now plz guide | |
11-26-2016, 13:13 | #7 (permalink) | |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
To solve the FRP, make the option of the previous post. | |
11-26-2016, 15:28 | #8 (permalink) | |
recover done with odin3 v3.12 version but frp not remove when i try again reset frp by chimera tool again stuck on logo | |
11-26-2016, 20:06 | #9 (permalink) | |
https://www.youtube.com/watch?v=Xxo9sJoup6w 100% solved!!! | |
11-30-2016, 12:36 | #11 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | 1.Download and installRealTerm program 2.Download and copy com.rootjunky.frpbypass-1.0.apk to the device micro sdcard or download once into the device. 3.Start phone and connect to WIFI also plug into the computer with your usb cable. 4.Start RealTerm on your pc and under pisplay check the box HALF DUPLEX 5.Right click on my computer and select manage once it opens click device manager then modems 6.Under modems you should see a Samsung device. right click it then select properties 7.Once the properties window opens select modem tab and see what port it is on like com5 for an example 8.Now that you know the com port number close all device manager windows and open RealTerm again 9.Under the ports tab in RealTerm enter your port number then click change. 10.Next, click the send tab. you will need to send these two commands with the Send ASCII button 11.First at+creg?\r\n 12.Then atd1234;\r\n com.sika524.android.quickshortcut - Download - 4shared - Saif Ur Rahman Android_6_Google_Account_Manager - Download - 4shared - Saif Ur Rahman Dev-Host - Realterm_BETA_3.0.0.30_setup.exe - The Ultimate Free File Hosting / File Sharing Service |
01-04-2017, 03:45 | #12 (permalink) |
Insane Poster Join Date: Apr 2016 Location: Nicaragua Age: 40
Member: 2555136 Status: Offline Thanks Meter: 31 | Frp solution G570F Download Samsung Factory Binary ( Combination ) COMBINATION_OJV_FA60_G570FXXU1APJ2_OJV1APJ2.zip After Download unzip combination firmware and u will find this file inside COMBINATION_OJV_FA60_G570FXXU1APJ2_OJV1APJ2_CL9555 172_QB11274596_REV00_user_mid_noship.tar.md5 Now Select This File In Z3X or Miracle Box or Any Samsung Flashing Tool ( uncheck all files except Sboot.bin and Boot.img ) Now Connect Your Phone In Download Mode ( Vol - + Home btn + power btn ) and write flash ( note :- only flash Sboot.bin and Boot.img no need to flash entire firmware ) and after flashing complete your phone will reboot to normal wait for complete boot. once your phone come in normal mode your phone adb mode should become enable. now with z3x or any other tool Reset FRP in ADB mode. Go to setting in phone and make factory reset from menu than flash phone back to original firmware worked like a charm with the version 6.0.1 (G570F) |
01-12-2017, 10:22 | #13 (permalink) | |
Major Poster Join Date: Feb 2003 Location: Tirunelveli,India
Member: 23148 Status: Offline Sonork: 100.1607393 Thanks Meter: 90 | Quote:
How to uncheck except boot and sboot in z3x? | |
01-12-2017, 12:44 | #15 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | If not a good result, try this: -Download and flash the Eng file through odin COMBINATION_OJV_FA60_G570FXXU1APJ2_OJV1APJ2_CL9555 172_QB11274596_REV00_user_mid_noship.tar.md5 -This will enable adb. Run the command to bypass activation adb shell content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1 - By Pass OK - Turn on oem unlocking and reset the phone Connect phone in download mode FRPwith chimera Reboot phone to download mode one more time to check if FRP is OFF" Full flash phone with the last firmware |
The Following User Says Thank You to gcceleghg For This Useful Post: |
