03-20-2018, 13:02 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Dear user! You have a very new version of firmware G928GXXX4XXXX with binary file: 4 and that is the problem because of chimera has as only option: 928GDDU1AOK1 11/2015 Binary: 1 To solve this problem you should use a combination file like this one of the same binary G928G_COMBINATION_FA51_G928IDVU4APJ1_FACTORY Once the flash is made 1. connect the phone to chimera in NORMAL MODE and make FRP Reset Lock-New 2. Delete the phone from the menu 3. Flash Stock Firmware You can also use this Combination file: G928i_COMBINATION_FA51_G928IDVU4APJ1_FACTORY |
The Following User Says Thank You to gcceleghg For This Useful Post: |
05-10-2018, 13:57 | #3 (permalink) | |
No Life Poster Join Date: Aug 2014 Location: brazil - brasilia
Member: 2235684 Status: Offline Thanks Meter: 417 | Quote:
