05-14-2020, 12:35 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Hatfield Harare Zimbabwe Age: 42
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Samsung J260F u5 can't patch cert Code: Chimera Mobile Phone Utility version: 24.71.1209 @ 2020-05-14 Printing phone history Repair IMEI 5/2/2020 12:15:03 PM Get Info 5/2/2020 12:14:05 PM Patch certificate started Unable to detect IMEI number. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J260F Sales Code: XFV Country Code: South Africa Timezone: Africa/Harare Android Version: 8.1.0 [M1AJB] [SDK 27] Build Date: Wed Jan 8 19:21:52 KST 2020 PDA Version: J260FXXS5ATA3 [january 2020, rev3] Phone Version: J260FXXS5ATA1 [january 2020, rev1] CSC Version: J260FOJM5ATA3 [january 2020, rev3] Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: RZ8KC1H7L6R Battery Status: 4.08V (75%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Warranty Bit: 1 Security Patch: 2020-01-01 Preparing... Checking root access. The phone is rooted by: 20.3:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Unable to patch certificate. Finished at local time: [05.14.20 13:30:03] WorkID: 95231276 |
05-14-2020, 12:48 | #2 (permalink) |
No Life Poster Join Date: Mar 2018 Location: Future.... ✌️
Member: 2825953 Status: Offline Thanks Meter: 246 | it has already done http://forum.gsmhosting.com/vbb/f898...-done-2834328/ |
The Following 2 Users Say Thank You to -=P.F.U=- For This Useful Post: |
05-14-2020, 13:30 | #3 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Online Thanks Meter: 23,781 | reply Hi, install complete stock firmware on your device. After it you need have a successfully imei repair process, when it is done root your device at least start patch cert. Best regards Nicole Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
05-16-2020, 10:20 | #6 (permalink) | |
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Quote:
Repair IMEI done : Code: Chimera Mobile Phone Utility version: 24.80.0719 @ 2020-05-16 Printing phone history Knoxguard Remove 5/16/2020 8:38:07 AM Rmm Remove 5/16/2020 8:36:32 AM Repair IMEI 5/13/2020 1:19:20 PM Patch Certificate 5/13/2020 1:16:43 PM Patch Certificate 5/13/2020 12:33:49 PM Repair started Unable to detect IMEI number. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J260F Sales Code: XFV Country Code: South Africa Timezone: Africa/Harare Android Version: 8.1.0 [M1AJB] [SDK 27] Build Date: Wed Jan 22 18:44:48 KST 2020 PDA Version: J260FXXU5ATA5 [january 2020, rev5] Phone Version: J260FXXU5ASL1 [december 2019, rev1] CSC Version: J260FOJM5ATA2 [january 2020, rev2] Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: RZ8K91MG6YK Battery Status: 4.23V (95%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Warranty Bit: 1 Security Patch: 2020-01-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 356354667567581 Repaired imei: 356235268126820 Successfully finished. Finished at local time: [05.16.20 10:39:19] WorkID: 95405780 Cert Patching Done : Code: Chimera Mobile Phone Utility version: 24.80.0719 @ 2020-05-16 Printing phone history Knoxguard Remove 5/16/2020 9:16:03 AM Knoxguard Remove 5/16/2020 9:06:14 AM Patch Certificate 5/16/2020 8:51:58 AM Repair IMEI 5/16/2020 8:39:27 AM Knoxguard Remove 5/16/2020 8:38:07 AM Patch certificate started Unable to detect IMEI number and baseband version. It seems that the modem does not work or the network is unavailable/disabled. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J260F Sales Code: XFV Country Code: South Africa Timezone: Africa/Harare Android Version: 8.1.0 [M1AJB] [SDK 27] Build Date: Wed Jan 22 18:44:48 KST 2020 PDA Version: J260FXXU5ATA5 [january 2020, rev5] Phone Version: J260FXXU5ASL1 CSC Version: J260FOJM5ATA2 [january 2020, rev2] Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: RZ8K91MG6YK Battery Status: 4.23V (95%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Warranty Bit: 1 Security Patch: 2020-01-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [05.16.20 11:17:04] WorkID: 95407966 All is well now keep up the good customer support | |
The Following 2 Users Say Thank You to johnmadzeka1 For This Useful Post: |
