Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 12-24-2016, 22:56   #1 (permalink)
Member: 679815
Thanks Meter: 3
Samsung J710FN or J710F
Hello, I would like to flash a Samsung J710.
On the back is J710FN. In Download Mode J710F.
How can I flash it? It always breaks off or it
comes up with the wrong model. Many thanks for your help.
The Following User Says Thank You to Isi777 For This Useful Post:
Old 12-25-2016, 15:30   #2 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,335
Hi, use version detected on ODIN Mode.... you will not have problems.... 100% guarantee
Best Regards
Shensohau
The Following User Says Thank You to Shensohau For This Useful Post:
Old 10-20-2017, 14:42   #3 (permalink)
Member: 2643730
Thanks Meter: 1,115
how to detect version in odin , explain in detail
Old 10-20-2017, 15:01   #4 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
Dear Sir!
Both models are compatible in memory and in processor but it is always convenient to use the firmware corresponding to your phone.
To know which is the correct model you can do these two things:
1. Check the label below the battery model number
2. Put the phone in download mode and verify the data on the screen of the model. (this method is the safest)
3. Also if you put the phone in recovery mode, on the screen in the second line you can see what firmware has inside your phone.
As Mr. Shensohau says, you can use Odin to flash your phone but you always have to check the model number so you do not have problems.
Once the model is detected, you can flash with chimera as well.
Old 10-20-2017, 18:19   #5 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,800
J710F as in download mode
download mode is the 100% and u can rely on it
The Following 2 Users Say Thank You to profkefah For This Useful Post:
Page generated in 0.13630 seconds with 8 queries
