04-04-2019, 13:09 | #1 (permalink) |
Freak Poster Join Date: Mar 2018 Location: Pakistan / Islamabad
Member: 2822559 Status: Offline Sonork: 100.1683406 Thanks Meter: 101 | Samsung Note 8 N950f dm-verity verification failed Im flash U5 Version All Firmware and new latest firmware 9.0 but Still Same Problem Im Flash Combination file ok Phone Complete boot On working for combination file and after flash complete file and still come back same problem dm-verity verification failed recovery mode Please Help Me Check this Image https://i.postimg.cc/cH07Fyqv/IMG-8042.jpg https://i.postimg.cc/g0XR4zBc/IMG-8043.jpg Please Help. |
04-04-2019, 15:09 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Hi, try to install original firmware with chimera, just do not forget to enable "autoroot" option. Best regards Nicole Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
04-06-2019, 08:11 | #5 (permalink) | |
No Life Poster Join Date: Mar 2019 Location: saturn
Member: 2901996 Status: Offline Thanks Meter: 917 | Quote:
Flash This and post result.its for android 9. N950F android 9 DRK credits original uploader. | |
The Following 2 Users Say Thank You to Titan_GSM For This Useful Post: |
04-29-2019, 17:37 | #9 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
Once the combination has been installed, fail to reset the frp via adb via chimera if the n950f model is supported or select another model from chimera and reset the frp via adb or use another tool and box that supports the n950f model for frp reset adb. Once the FRP is reset via ADB, disable the OEM unlock you make a factory reset on the phone, done that you do the firmware flash in 4 files ap, bl, cp, home_csc, you'll see that the phone will remain locked in dm-verity drk error, from there root with the twrp install super su and install file the dm-verity encrypted disable file to disable the drk error | |
