09-17-2014, 15:15 | #1 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Armenia Age: 46
Member: 15440 Status: Offline Thanks Meter: 15 | Samsung S5 mini G800H can't unlock??? Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G800H Android Version: 4.4.2 Sales Code: THR PDA Version: G800HXXU1ANGF Phone Version: G800HXXU1ANGF CSC Version: G800HOJV1ANG5 Product Code: SM-G800HZKDTHR HIDSw Version: G800HXXU1ANGF/G800HOJV1ANG5/G800HXXU1ANGF/G800HXXU1ANGF Board Platform: msm8226 Serial Number: R51F80259FY Imei: 355**********49 Unique Number: C160418E1029851 Connections: AT,MTP,MTP Finished successfully. Finished at local time: [09.17.14 18:11:15] WorkID: 2159588 Unlocking... 1. Disconnect micro USB cable. 2. On dial window enter *#0808# and set DM+MODEM+ADB. 3. Select OK on phone display. 4. Connect micro UART cable. 5. Click OK button. Testing availability. Be patient! Do NOT disconnect the phone! Unable to unlock. Finished at local time: [09.17.14 18:13:25] WorkID: 2159619 |
09-17-2014, 15:30 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,786 | answer Dear Kot, Please try to root the phone with something else (alternatives here) When you're done, do the factory unlock again with the micro USB method. Kind regards, Chimera Team Quote:
09-17-2014, 15:51 | #4 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | answer Users repair phones with 4.4.2, pda=G800HXXU1ANGD, cp=G800HXXU1ANGD, csc=G800HOXY1ANGD details so try to put this fw then try to root it. Or you can just use this info as a start for your search. Kind regards, Chimera Team |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
11-28-2014, 10:59 | #7 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 44
Member: 136052 Status: Offline Thanks Meter: 75 | unlock successfully Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G800H Android Version: 4.4.2 Sales Code: KSA PDA Version: G800HXXU1ANGF Phone Version: G800HXXU1ANGF CSC Version: G800HOJV1ANG5 Product Code: SM-G800HZDDKSA HIDSw Version: G800HXXU1ANGF/G800HOJV1ANG5/G800HXXU1ANGF/G800HXXU1ANGF Board Platform: MSM8226 Serial Number: RF1F904RBDR Imei: 35**********40 Unique Number: C1604E02BD75571 Connections: AT,MTP Battery Status: 4.33V (99%) Network Type: GSM Unlocking... Preparing image. Testing availability. Be patient! Do NOT disconnect the phone! Preparing MSL. Be patient! Do NOT disconnect the phone! This operation cost 589 credits. New balance: 500 Processing. Restart phone by using the phone's menu if it does not restart automatically! If needed use unlock code "12345678". Finished successfully. Finished at local time: [11.28.14 13:46:59] WorkID: 3106654 |
11-28-2014, 11:20 | #8 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear Denozaur, In our system it shows succesfully finished, do you have any problem? Best Regards, Chimera Team Quote:
11-28-2014, 13:41 | #9 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
CF-Root Download samsung SM-G800H kmini3gxx kmini3g Contain .tar.md5 files flashable in ODIN as PDA. Make sure your device is in ODIN download mode (usually you can get there by holding VolDown+Home+Power when the device is turned off), then start the included Odin3-v1.85.exe file, press the PDA button, select the .tar.md5 file, and click Start. You can find more detailed instructions and assistance at XDA. A modified recovery and cache partition will be flashed, which will install (only) SuperSU, then clean-up the cache partition and re-flash the stock recovery. For the root to work, the device must reboot into recovery. Most devices will do this automatically after flashing these files, but in case that does not happen, please boot into recovery manually. | |
The Following User Says Thank You to gcceleghg For This Useful Post: |
11-28-2014, 14:22 | #10 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear gcceleghg, Thank you very much for your quick help and feedback. Best Regards, Chimera Team Quote:
02-03-2015, 15:54 | #12 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear shaheddin, Sorry to say but we have no solution for it at the moment. In the past we had a function Factory Unlock but we needed to remove that due to unavailability. Please be patient until we will have a new solution. It is coming soon. Best Regards, Chimera Team |
02-17-2015, 02:39 | #13 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2347837 Status: Offline Thanks Meter: 1 | Please unlocked to all networks samsung galaxy mini SM- G800h I am new at this and I mean to you to please I need your help to release my Samsung Galaxy Mini S5 SM- G800H . I appreciate your help. IMEI: 3536xxxxxxxxxxx/01 Last edited by paulo pessoa; 02-17-2015 at 03:10. Reason: Imei the public |
02-17-2015, 03:09 | #14 (permalink) |
Product Supporter Join Date: Dec 2010 Location: Brazil Fortaleza Ceará
Member: 1474113 Status: Offline Sonork: 100.1604217 Thanks Meter: 472 | good evening sir, we are in trouble in our direct unlock server, we ask our customers to be more patient team working to solve the problem quickly the the possible. regards, chimera team |
The Following User Says Thank You to paulo pessoa For This Useful Post: |
02-17-2015, 09:31 | #15 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear osmer86, Unfortunately you have to wait a bit because we don't have proper solution at the moment. Our whole team is working on it, solution is coming soon. Please keep following and checking our updates. Best Regards, Chimera Team |
