Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 09-28-2016, 18:57   #1 (permalink)
Member: 908175
Thanks Meter: 314
samsung s7 edge g935f frp cant reset
i have samsung s7 edge trying to reset frp 6.0.1 but phone wont restert after that and now dont even goes in download mode but i have f;lashed it with samsung kies done agin but stuck agin on samsung wont reboot but flashed it agin with sasmung nd phone back to normal but how can i reset frp on this dont want to trye 3rd time its gona stuck agin so plz give me proper info to reset that thanks
Old 09-28-2016, 19:09   #2 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
Dear user!
To support Chimera can help you, you need to upload to post the number of work ID with Chimera
Old 09-29-2016, 09:51   #3 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 24,053
reply
Dear Sir,
please send us work id for the process and we can check what can be the problem.
Thank you in advance!
Best regards
Nicole
Old 10-04-2016, 18:02   #4 (permalink)
Member: 908175
Thanks Meter: 314
here is id 13778451
here 13875967
been on this for few days still no luck
Old 10-04-2016, 18:03   #5 (permalink)
Member: 908175
Thanks Meter: 314
it does and stuck on samsung logo then wont do any thing i have flash this phone about 10 times now it has 6.0.1
Old 10-05-2016, 13:38   #6 (permalink)
Member: 1787203
reply
Dear Sir,
please try to start an info function on the phone and send us the work id fo the process.
Best regards
Nicole
Old 10-05-2016, 13:52   #7 (permalink)
Member: 908175
Thanks Meter: 314
now stuck here
Printing phone history
SW Change
05/10/2016
11:22:56
Reset FRP Lock
05/10/2016
11:15:42
Reset FRP Lock
05/10/2016
11:14:03
Reset FRP Lock
05/10/2016
11:12:07
SW Change
04/10/2016
16:54:55
[Reset FRP lock started]
Checking boot image...
Present.
Flashing boot image...
After reboot, if the boot process get stuck, you can install a stock firmware.
Flashing firmware...
Waiting for download mode.
Connecting.
Reading PIT.
Flashing sboot.bin
Flashing boot.img
Restarting phone.
Waiting for device. Be patient! Do NOT disconnect the phone!
Old 10-05-2016, 13:55   #8 (permalink)
Member: 908175
Thanks Meter: 314
now its done here but phone stuck on samsung logo
Chimera Mobile Phone Utility version: 11.53.2033 @ 2016-10-05
SW Change
05/10/2016
11:22:56
Reset FRP Lock
05/10/2016
11:15:42
Reset FRP Lock
05/10/2016
11:14:03
Reset FRP Lock
05/10/2016
11:12:07
SW Change
04/10/2016
16:54:55
Present.
Connecting.
Reading PIT.
Flashing sboot.bin
Flashing boot.img
Restarting phone.
Waiting for ADB connection. Be patient! Do NOT disconnect the phone!
Processing...
To avoid any problems caused by the combination boot, please install a stock firmware.
To complete FRP Reset goto "Backup and reset" and select "Factory data reset".
Succeeded.
Finished successfully.
Finished at local time: [10.05.16 13:54:23]
WorkID: 13971611
where shal i get this stock firmwear thanks
Old 10-05-2016, 14:12   #9 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
You can use these firmware to flash your phone and then make FRP with Chimera Tool.
6.0.1 SM-G935F G935FXXU1APB3 02/04/2016
6.0.1 SM-G935F G935FXXU1APAW 01/29/2016
https://samsung-firmware.org/model/SM-G935F/page/43
Also you can flash Sboot (BL) and Modem (CP) only to downgrade the firmware using Odin into download mode.
Important: autoreboot uncheck the box in Odin.
When finished, your phone will continue into download mode and then you try again FRP with Chimera.
CP_G935FXXU1APE9
https://www.androidfilehost.com/?fid=24533103863143010
BL_G935FXXU1APE9
https://www.androidfilehost.com/?fid=24533103863143009
The Following User Says Thank You to gcceleghg For This Useful Post:
Old 10-05-2016, 14:19   #10 (permalink)
Asad ali khan's Avatar
Member: 2454192
Sonork: 100.1674433
Thanks Meter: 694
1.Download and installRealTerm program
2.Download and copy com.rootjunky.frpbypass-1.0.apk to the device micro sdcard or download once into the device.
3.Start phone and connect to WIFI also plug into the computer with your usb cable.
4.Start RealTerm on your pc and under pisplay check the box HALF DUPLEX
5.Right click on my computer and select manage once it opens click device manager then modems
6.Under modems you should see a Samsung device. right click it then select properties
7.Once the properties window opens select modem tab and see what port it is on like com5 for an example
8.Now that you know the com port number close all device manager windows and open RealTerm again
9.Under the ports tab in RealTerm enter your port number then click change.
10.Next, click the send tab. you will need to send these two commands with the Send ASCII button
11.First at+creg?\r\n
12.Then atd1234;\r\n
13.Look at your phone and the dailer will pop up
The Following 2 Users Say Thank You to Asad ali khan For This Useful Post:
Old 10-06-2016, 11:59   #11 (permalink)
Member: 908175
Thanks Meter: 314
still no luck i think this phone has new secrty but i think this should not ad fake update to cofuse the custmers there is no way to to remove frp on this g935f with this tool all fake but might b in near feture some thing come
Old 10-06-2016, 12:09   #12 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
Did you try this:
Or this:
CP_G935FXXU1APE9
BL_G935FXXU1APE9
Old 10-06-2016, 14:45   #13 (permalink)
Member: 908175
Thanks Meter: 314
yes i have try this but same phone stuck on samsung logo
Old 10-06-2016, 16:42   #14 (permalink)
Member: 1787203
reply
Dear User,
If you get stuck at the samsung logo you have to put the phone back to download mode then you can do a firmware update. After the update the phone will working. If you click on the reset FRP - new function and you choose the model number you can see a FW type and a date. The FRP reset will working with that FW version or with an older one.
Best Regards
Chimera Team
The Following 4 Users Say Thank You to Chimera Tool For This Useful Post:
Old 10-07-2016, 22:51   #15 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
I think your phone has new firmware inside. Like G935FXXU1B...
and Chimera writes eng boot of G935FXXU1A... Therefore, it stuck
on logo. You can full flash with G935FXXU1A... Factory reset phone
and then use New FRP method of Chimera. It should power on with
ADB enabled.
Hope this helps.
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Page generated in 0.29789 seconds with 8 queries
