09-28-2016, 18:57 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: UK NETWORK SOURCE
Member: 908175 Status: Offline Thanks Meter: 314 | samsung s7 edge g935f frp cant reset |
09-28-2016, 19:09 | #2 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
To support Chimera can help you, you need to upload to post the number of work ID with Chimera | |
09-29-2016, 09:51 | #3 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 24,053 | reply Dear Sir, please send us work id for the process and we can check what can be the problem. Thank you in advance! Best regards Nicole Quote:
10-05-2016, 13:52 | #7 (permalink) |
Member: 908175 Status: Offline Thanks Meter: 314 | now stuck here Printing phone history SW Change 05/10/2016 11:22:56 Reset FRP Lock 05/10/2016 11:15:42 Reset FRP Lock 05/10/2016 11:14:03 Reset FRP Lock 05/10/2016 11:12:07 SW Change 04/10/2016 16:54:55 [Reset FRP lock started] Checking boot image... Present. Flashing boot image... Flashing boot image. After reboot, if the boot process get stuck, you can install a stock firmware. Flashing firmware... Waiting for download mode. Connecting. Reading PIT. Flashing sboot.bin Flashing boot.img Restarting phone. Waiting for device. Be patient! Do NOT disconnect the phone! |
10-05-2016, 13:55 | #8 (permalink) |
Member: 908175 Status: Offline Thanks Meter: 314 | now its done here but phone stuck on samsung logo Chimera Mobile Phone Utility version: 11.53.2033 @ 2016-10-05 Printing phone history SW Change 05/10/2016 11:22:56 Reset FRP Lock 05/10/2016 11:15:42 Reset FRP Lock 05/10/2016 11:14:03 Reset FRP Lock 05/10/2016 11:12:07 SW Change 04/10/2016 16:54:55 [Reset FRP lock started] Checking boot image... Present. Flashing boot image... Flashing boot image. After reboot, if the boot process get stuck, you can install a stock firmware. Flashing firmware... Waiting for download mode. Connecting. Reading PIT. Flashing sboot.bin Flashing boot.img Restarting phone. Waiting for device. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Processing...  To avoid any problems caused by the combination boot, please install a stock firmware. To complete FRP Reset goto "Backup and reset" and select "Factory data reset". Succeeded. Finished successfully. Finished at local time: [10.05.16 13:54:23] WorkID: 13971611 where shal i get this stock firmwear thanks |
10-05-2016, 14:12 | #9 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | You can use these firmware to flash your phone and then make FRP with Chimera Tool. 6.0.1 SM-G935F G935FXXU1APB3 02/04/2016 6.0.1 SM-G935F G935FXXU1APAW 01/29/2016 https://samsung-firmware.org/model/SM-G935F/page/43 Also you can flash Sboot (BL) and Modem (CP) only to downgrade the firmware using Odin into download mode. Important: autoreboot uncheck the box in Odin. When finished, your phone will continue into download mode and then you try again FRP with Chimera. CP_G935FXXU1APE9 https://www.androidfilehost.com/?fid=24533103863143010 BL_G935FXXU1APE9 https://www.androidfilehost.com/?fid=24533103863143009 |
The Following User Says Thank You to gcceleghg For This Useful Post: |
10-05-2016, 14:19 | #10 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Everywhere Age: 29
Member: 2454192 Status: Offline Sonork: 100.1674433 Thanks Meter: 694 | 1.Download and installRealTerm program 2.Download and copy com.rootjunky.frpbypass-1.0.apk to the device micro sdcard or download once into the device. 3.Start phone and connect to WIFI also plug into the computer with your usb cable. 4.Start RealTerm on your pc and under pisplay check the box HALF DUPLEX 5.Right click on my computer and select manage once it opens click device manager then modems 6.Under modems you should see a Samsung device. right click it then select properties 7.Once the properties window opens select modem tab and see what port it is on like com5 for an example 8.Now that you know the com port number close all device manager windows and open RealTerm again 9.Under the ports tab in RealTerm enter your port number then click change. 10.Next, click the send tab. you will need to send these two commands with the Send ASCII button 11.First at+creg?\r\n 12.Then atd1234;\r\n 13.Look at your phone and the dailer will pop up |
10-06-2016, 11:59 | #11 (permalink) |
Member: 908175 Status: Offline Thanks Meter: 314 | still no luck i think this phone has new secrty but i think this should not ad fake update to cofuse the custmers there is no way to to remove frp on this g935f with this tool all fake but might b in near feture some thing come |
10-06-2016, 12:09 | #12 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Did you try this: You can use these firmware to flash your phone and then make FRP with Chimera Tool. 6.0.1 SM-G935F G935FXXU1APB3 02/04/2016 6.0.1 SM-G935F G935FXXU1APAW 01/29/2016 https://samsung-firmware.org/model/SM-G935F/page/43 Or this: Also you can flash Sboot (BL) and Modem (CP) only to downgrade the firmware using Odin into download mode. Important: autoreboot uncheck the box in Odin. When finished, your phone will continue into download mode and then you try again FRP with Chimera. CP_G935FXXU1APE9 https://www.androidfilehost.com/?fid=24533103863143010 BL_G935FXXU1APE9 https://www.androidfilehost.com/?fid=24533103863143009 |
10-06-2016, 16:42 | #14 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 24,053 | reply Dear User, If you get stuck at the samsung logo you have to put the phone back to download mode then you can do a firmware update. After the update the phone will working. If you click on the reset FRP - new function and you choose the model number you can see a FW type and a date. The FRP reset will working with that FW version or with an older one. Best Regards Chimera Team |
The Following 4 Users Say Thank You to Chimera Tool For This Useful Post: |
10-07-2016, 22:51 | #15 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | I think your phone has new firmware inside. Like G935FXXU1B... and Chimera writes eng boot of G935FXXU1A... Therefore, it stuck on logo. You can full flash with G935FXXU1A... Factory reset phone and then use New FRP method of Chimera. It should power on with ADB enabled. Hope this helps. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
