04-18-2019, 13:58 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Ten Walls Age: 32
Member: 548940 Status: Offline Thanks Meter: 55 | Samsung S8 repair done Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G950F Sales Code: NEE Timezone: Europe Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Wed Dec 26 11:34:58 KST 2018 PDA Version: G950FXXS4CRLB [december 2018, revB] Phone Version: G950FXXU4CRKB [november 2018, revB] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: R Imei: Battery Status: 3.69V (17%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-01-01 Data Encryption State: unencrypted Preparing... Checking current patchcert. Checking modem. Checking root. Checking boot image. Be patient! Do NOT disconnect the phone! Selinux could cause problems. If the patchcert does not work, try another root solution. Reading data... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. |
The Following User Says Thank You to acmerw For This Useful Post: |
