10-27-2017, 13:17 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | The solution is here: http://forum.gsmhosting.com/vbb/f898...olved-2246651/ |
10-27-2017, 13:59 | #3 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: Macedonia Age: 49
Member: 1246981 Status: Offline Sonork: 100.1590424 Thanks Meter: 316 | Quote:
10-27-2017, 14:23 | #4 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Dear Sir! According to what I have left in the attached link, you can first try directly with chimera by putting the phone in download mode and choose the option reset FRP New Lock and choose the option for this model. I recommend two things: 1. Once the process has been completed, if you have obtained adb communication, then do the process again with the phone in normal mode and then delete it from the menu of the phone 2. Flash from the phone with the latest version of the firmware. The other option is to use the combination file. 1. Flash with the combination file 2. Connect the phone in normal mode 3. Do the FRP process |
10-27-2017, 18:33 | #5 (permalink) |
Member: 1246981 Status: Offline Sonork: 100.1590424 Thanks Meter: 316 | after i flash with combination file and reset frp i try to back to original firmware but i got error with chimera please help me to revive this phone here is log Processing firmware... Flashing firmware... Waiting for download mode. Connecting. SBL Info: Model: SM-J530F, Region: EUR, Provider: OPEN, PDA: J530FXXU1AQED Reading PIT. Checking firmware compatibility. RP SWREV: B:1 K:0 S:0 The firmware version is compatible. Flashing boot.img Flashing recovery.img Flashing system.img Flashing sboot.bin Flashing param.bin Flashing cm.bin Flashing modem.bin Flashing cache.img Flashing hidden.img Restarting phone. It is possible that the data depending on the service-provider (hidden) has not enough space or it is not compatible. Unable to restart. Restarting failed. Finished at local time: [10.27.17 19:31:27] WorkID: 28420756 |
