11-09-2019, 03:20 | #827 (permalink) |
Insane Poster Join Date: Jul 2011
Member: 1608954 Status: Offline Sonork: elmazetaz Thanks Meter: 26 | Repair IMEI SAMSUNG A720F U8 Process done thank you very much team keep working let's go for the best tool |
The Following User Says Thank You to elmazetaz For This Useful Post: |
11-09-2019, 20:12 | #829 (permalink) | |
Major Poster Join Date: Dec 2017 Location: sao paulo vicente de carvalho
Member: 2788157 Status: Offline Thanks Meter: 12 | sucess with Quote:
Sales Code: 3IE Country Code: Ireland Timezone: Europe/London Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Thu Aug 8 14:01:20 KST 2019 PDA Version: G935FXXS6ESH1 [august 2019, rev1] Phone Version: G935FXXS6ESH1 [august 2019, rev1] CSC Version: G935F3IE6ESH1 [august 2019, rev1] | |
11-09-2019, 21:26 | #830 (permalink) |
Junior Member Join Date: Oct 2019 Location: Russia
Member: 2933941 Status: Offline Thanks Meter: 0 | Does anybody know that they beated KnoxGuard? 1 August security patch. Got stuck KG even if device was 170 hours ON. (modem is broken. No IMEI. I used the device only with via wifi) |
11-19-2019, 13:10 | #835 (permalink) | |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Quote:
br on U4 you need to use phone on stock with single sim. | |
11-21-2019, 11:17 | #836 (permalink) |
Product Supporter Join Date: Apr 2016 Location: India
Member: 2562751 Status: Offline Thanks Meter: 60 | A105F U3 Pacth Cert Not Working After Pacth Cert When Phone auto reboot than Phon SHow Only Official Binary Are allowed To Flash & Phone Not Run Code: Chimera Mobile Phone Utility version: 23.02.1046 @ 2019-11-21 Printing phone history Patch Certificate 11/21/2019 10:03:58 AM Patch Certificate 11/21/2019 9:54:10 AM Repair IMEI 11/21/2019 9:51:18 AM Rmm Unlock 11/21/2019 9:48:36 AM Repair IMEI 11/21/2019 8:33:01 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A105F Sales Code: BKD Country Code: Iraq Timezone: Asia/Dhaka Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Sep 17 21:20:50 KST 2019 PDA Version: A105FDDU3ASI6 [september 2019, rev6] Phone Version: A105FDDU3ASI2 [september 2019, rev2] CSC Version: A105FOJM3ASI3 [september 2019, rev3] Product Code: MID HIDSw Version: A105FDDU3ASI6/A105FOJM3ASI3/A105FDDU3ASI2/A105FDDU3ASI6 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: R28M618D7MT Imei: 357293100******** Unique Number: CBJ00EBC5DC1356 Connections: AT,MTP Battery Status: 4.11V (84%) Network Type: GSM SIM Status: ABSENT,LOADED Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-09-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 21.0:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.21.19 16:06:59] WorkID: 80114086 |
11-21-2019, 14:38 | #838 (permalink) |
Junior Member Join Date: Nov 2019 Location: Pakistan
Member: 2936988 Status: Offline Sonork: [email protected] Thanks Meter: 29 | This is cool Update! |
