03-02-2021, 19:06 | #1 (permalink) |
No Life Poster Join Date: Jul 2011 Location: montreal
Member: 1612872 Status: Offline Sonork: 1613495 Thanks Meter: 178 | Lg k410m prob frp Removing factory reset protection... Waiting for device to disconnect... Device disconnected. Phone detected. Invalid response Finished at local time: [03.02.21 13:03:40] WorkID: 126692992 |
03-03-2021, 11:08 | #2 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,734 | reply Dear User, Please update your device in Download mode with the Firmware Update service. Then do the FRP RESET again on the phone with the Chimera Tool. Best regards Sab |
03-03-2021, 18:31 | #3 (permalink) | |
Member: 1612872 Status: Offline Sonork: 1613495 Thanks Meter: 178 | Quote:
Printing phone history Remove FRP lock 02/03/2021 6:02 PM This procedure might not have been tested with this model yet, and might not work. Please be aware of the potential dangers! Firmware Update started Downloading firmware... Firmware downloaded successfully Preparing firmware files... Warning! The following model name mismatch(es) detected: This phones model name is LM-K410WM, while this firmware is for model LG-LMK410WM according to the firmware server. Flashing a firmware on the phone that is not made for this model can cause brick! Do you want to continue? Changing to download mode ... Trying to boot the phone into download mode... Phone detected. Flashing firmware... USB Connection Established An error occurred during LG update: Error: 0x80000001, Invalid command response code = 0x80000001 Finished at local time: [03.03.21 12:20:04] WorkID: 126810460 | |
03-03-2021, 18:44 | #4 (permalink) |
Member: 1612872 Status: Offline Sonork: 1613495 Thanks Meter: 178 | Chimera Mobile Phone Utility version: 27.71.0928 @ 2021-03-03 Printing phone history SW Change 03/03/2021 5:03 PM Remove FRP lock 02/03/2021 6:02 PM Removing factory reset protection... Trying to boot the phone into download mode... Phone detected. Successfully finished. Finished at local time: [03.03.21 12:41:51] WorkID: 126815133 |
The Following 2 Users Say Thank You to katitous For This Useful Post: |
12-22-2021, 22:45 | #5 (permalink) | |
Junior Member Join Date: Oct 2016 Location: Argentina
Member: 2636477 Status: Offline Thanks Meter: 1 | Quote:
Current version is not available for user. Cant find matched carrier NT-Code:0 | |
12-23-2021, 09:53 | #8 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,734 | reply Dear User, IF you use the official flash files and not custom firmware's then basically you cannot brick the device unless you flash a firmware that is too old for the phone. Best regards Sab Chimera team |
12-23-2021, 15:24 | #9 (permalink) |
Member: 2636477 Status: Offline Thanks Meter: 1 | I try to flash but i have this error Downloading firmware... Firmware downloaded successfully Preparing firmware files... Firmware extraction Warning! The following model name mismatch(es) detected: This phones model name is LM-K510HM, while this firmware is for model LG-LMK510HM according to the firmware server. This phones model name is LM-K510HM, while this firmware is for model LG-K510 according to the DZ file (K51020a_00_user-signed-ARB0_CLR_COM_OP_1223.dz). ?Flashing a firmware on the phone that is not made for this model can cause brick! Do you want to continue? Changing to download mode ... Trying to boot the phone into download mode... Phone detected. Flashing firmware... USB Connection Established An error occurred during LG update: Error: 0x80000001, Invalid command response code = 0x80000001 Finished at local time: [12.22.21 22:24:39] WorkID: 163229236 |
