03-15-2018, 18:54 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: Macedonia Age: 49
Member: 1246981 Status: Offline Sonork: 100.1590424 Thanks Meter: 316 | sm-a510f help please [Read codes started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A510F Sales Code: MBM Country Code: MACEDONIA Timezone: Europe/Skopje Android Version: 7.0 [NRD90M] Build Date: Wed Jan 31 12:25:51 KST 2018 PDA Version: A510FXXU5CRB1 [february 2018, rev1] Phone Version: A510FXXU5CRA3 [january 2018, rev3] CSC Version: A510FMBM5CRB1 [february 2018, rev1] Product Code: MBM HIDSw Version: A510FXXU5CRB1/A510FMBM5CRB1/A510FXXU5CRA3/A510FXXU5CRB1 Board Platform: EXYNOS5 Modem Platform: SHANNON310 Serial Number: RF8HA0JL69J Imei: 354361081124131 Unique Number: C0000C3DDC84F73 Connections: AT,MTP Battery Status: 3.77V (38%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 0 Security Patch: 2018-02-01 Data Encryption State: unencrypted Reading Codes... Searching serial port. Be patient! Do NOT disconnect the phone! Serial port found on COM281 Reading data. Be patient! Do NOT disconnect the phone! Inappropriate modem version. Try using an older modem. WARNING! You only have to flash the modem.bin from the firmware! Read codes failed. Finished at local time: [03.15.18 18:53:16] WorkID: 34846728 |
03-15-2018, 21:10 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Dear Sir! The chimera software is giving you the information in the operation logo and shows you the causes of the failed operation. Inappropriate modem version. Try using an older modem. WARNING! You only have to flash the modem.bin from the firmware! Read codes failed. You should use an older and binary modem: 5 |
03-16-2018, 10:32 | #4 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, try just to downgrade modem for that device, our repository will be update with new firmwares soon... Best Regards Shensohau |
