08-18-2019, 10:44 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | SM-A520F This modem is not appropriate (A520FXXSBCSF8). Please downgrade if possible! Printing phone history Patch Certificate 8/5/2019 11:33:18 AM Patch Certificate 8/5/2019 11:31:06 AM Rmm Unlock 8/5/2019 11:17:32 AM Repair IMEI 8/5/2019 11:06:09 AM Repair IMEI 8/5/2019 11:03:33 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A520F Sales Code: TTT Country Code: TRINIDAD AND TOBAGO Timezone: Africa/Johannesburg Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Thu Jun 6 04:26:15 KST 2019 PDA Version: A520FXXSBCSF8 [june 2019, rev8] Phone Version: A520FXXSBCSF8 [june 2019, rev8] CSC Version: A520FUUBBCSF4 [june 2019, rev4] Product Code: TTT HIDSw Version: A520FXXSBCSF8/A520FUUBBCSF4/A520FXXSBCSF8/A520FXXSBCSF8 Board Platform: EXYNOS5 Modem Platform: SHANNON325 Serial Number: R28J511MN2V Imei: 350 Unique Number: CBJ106BB74D2A24 Connections: AT,MTP Battery Status: 3.86V (30%) Network Type: GSM SIM Status: READY Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: unencrypted Preparing... Checking current patchcert. Checking modem. Checking root. The phone is rooted by: 18.1:MAGISKSU (topjohnwu) Checking boot image. Be patient! Do NOT disconnect the phone! The knox is still valid. Because of the boot patch the warranty will void. Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. This modem is not appropriate (A520FXXSBCSF8). Please downgrade if possible! Unsupported modem version. Finished at local time: [08.18.19 11:39:12] WorkID: 70134397 |
08-19-2019, 09:12 | #2 (permalink) |
Insane Poster Join Date: Sep 2017 Location: ITALY
Member: 2754239 Status: Offline Thanks Meter: 16 | flash this modem https://shell.boxwares.com/Download.aspx?L=15568 |
08-20-2019, 16:45 | #4 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Not important just do unlock and after write back original firmware with a UB binary security. Or just write modem from combination firmware UB security and try unlock again after this should work without problem.
__________________ Please do not Personal Message me for help or troubleshooting. They will be ignored. Use the forums! To get Instant help use "search" & follow "sticky thread"..!!! By respecting/following forum rules,You will be respected .! |
09-02-2019, 15:22 | #5 (permalink) | |
Freak Poster Join Date: Aug 2014 Location: algeria
Member: 2232889 Status: Offline Thanks Meter: 91 | Quote:
12-18-2019, 12:41 | #13 (permalink) |
Member: 1444462 Status: Offline Thanks Meter: 1,337 | Finally After long time A520F has been successfully repair Chimera Mobile Phone Utility version: 23.30.0846 @ 2019-12-18 Printing phone history Patch Certificate 12/18/2019 11:26:38 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A520F Sales Code: TTT Country Code: TRINIDAD AND TOBAGO Timezone: Africa/Johannesburg Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Thu Jun 6 04:26:15 KST 2019 PDA Version: A520FXXSBCSF8 [june 2019, rev8] Phone Version: A520FXXSBCSF8 [june 2019, rev8] CSC Version: A520FUUBBCSF4 [june 2019, rev4] Product Code: TTT HIDSw Version: A520FXXSBCSF8/A520FUUBBCSF4/A520FXXSBCSF8/A520FXXSBCSF8 Board Platform: EXYNOS5 Modem Platform: SHANNON325 Serial Number: R58J64ELYVV Imei: 35 Unique Number: CBJ10AAF5EC0D44 Connections: AT,MTP Battery Status: 4.27V (100%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 20.1:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.18.19 13:31:45] |
The Following User Says Thank You to ..::GMSR::.. For This Useful Post: |
