04-10-2018, 13:44 | #1 (permalink) |
Product Supporter Join Date: Dec 2010 Location: Brazil Fortaleza Ceará
Member: 1474113 Status: Offline Sonork: 100.1604217 Thanks Meter: 472 | SM-F930F NOT Donwgrad FRP done Android 7.0 Chimera Versão de Mobile Phone Utility: 17.01.1125 @ 2018-04-10 Printing phone history Reset FRP Lock 10/04/2018 12:33:19 SW Change 07/04/2018 13:07:46 SW Change 07/04/2018 13:01:33 SW Change 06/04/2018 22:46:00 SW Change 06/04/2018 22:44:21 [Reset FRP/Reactivation lock started] Processing... Selected model: SM-G930F Waiting for download mode. Connecting. Initializing. Reading PIT. 1. Desconecta o cabo micro USB 2. Conecta o cabo micro UART 3. Click OK button.  1. Press and Hold Volume-Down Button 2. Press and Hold Power Button for 10-20 seconds The program will indicate when you can release the buttons. Release the buttons! The appropriate serial port has been found. Succeded. Finished successfully. Finished at local time: [04.10.18 09:38:49] WorkID: 36073272 |
The Following 4 Users Say Thank You to paulo pessoa For This Useful Post: |
04-14-2018, 13:42 | #3 (permalink) | |
Member: 1474113 Status: Offline Sonork: 100.1604217 Thanks Meter: 472 | Quote:
I have Succeeded here, I will arrange another apparatus and step process step by step Last edited by paulo pessoa; 04-14-2018 at 13:51. | |
04-28-2018, 00:03 | #5 (permalink) |
Insane Poster Join Date: Apr 2006
Member: 254924 Status: Offline Thanks Meter: 7 | I am having the same problem. Chimera says it's ok. But phone is still FRP locked. RP SWREV: B:2 K:0 S:0 7.0/NRD90M/G930FXXU2DRB6 [Reset FRP/Reactivation lock started] Processing... Selected model: SM-G930F Waiting for download mode. Connecting. Initializing. Reading PIT. 1. Disconnect micro USB cable 2. Connect micro UART cable 3. Click OK button.  1. Press and Hold Volume-Down Button 2. Press and Hold Power Button for 10-20 seconds The program will indicate when you can release the buttons. Release the buttons! The appropriate serial port has been found. Succeded. Finished successfully. WorkID: 36955689 |
05-29-2018, 15:39 | #8 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,769 | Thank you for the feedback. Case forwarded to my head developer colleague, I hope shortly we can fix that issue. Sorry for the inconveniences. Best regards Nicole |
05-30-2018, 23:18 | #9 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Now on earth Age: 48
Member: 75290 Status: Offline Thanks Meter: 57 | Sm-g930fxxs2drpi frp Hi! not work... SM-G930FXXS2DRPI Processing... Selected model: SM-G930F Waiting for download mode. Connecting. Initializing. Reading PIT. 1. Disconnect micro USB cable 2. Connect micro UART cable 3. Click OK button. 1. Press and Hold Volume-Down Button 2. Press and Hold Power Button for 10-20 seconds The program will indicate when you can release the buttons. Release the buttons! The appropriate serial port has been found. The process failed. Finished at local time: [05.31.18 00:09:12] WorkID: 38575527 |
06-09-2018, 14:12 | #10 (permalink) |
Member: 75290 Status: Offline Thanks Meter: 57 | G930F binary 2 FRP done - FW G930FXXS2DRDI My phone was on FW G930FXXS2DRDI I did like this... First flash with ODIN (very important) this version G930FXXS2DRAA_7.0_4File_Spain After flash phone goes in download mode with some errors, but after RESET phone normaly start. Than flesh with ODIN (very important) COMBINATION_FA60_G930FXXU2ARA2_CL7964511_QB1658129 6_REV00_user_mid_noship Now remove with Chimera FRP UFS with. After this job, phone in dowload mode should have FRP OFF. Now write FW with ODIN G930FXXS2DRAA_7.0_4File_Spain Phone startand and I was able to switch ON OEM unlock Now write version that you need BR ERSA Seb |
