Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 08-24-2019, 10:31   #1 (permalink)
..::GMSR::..'s Avatar
Member: 1444462
Thanks Meter: 1,337
SM-J730F ''U4'' Patch certificate Successfully finished but Still Emergency Calls
Chimera Mobile Phone Utility version: 22.12.0817 @ 2019-08-24
Patch certificate started
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-J730F
Sales Code: XEO
Country Code: Poland
Timezone: Africa/Johannesburg
Android Version: 9 [PPR1.180610.011] [SDK 28]
Build Date: Tue Jun 4 21:49:52 KST 2019
PDA Version: J730FXXU4CSF1 [june 2019, rev1]
Phone Version: J730FXXU4CSED [may 2019, revD]
CSC Version: J730FXEO4CSEE [may 2019, revE]
Product Code: XEO
HIDSw Version: J730FXXU4CSF1/J730FXEO4CSEE/J730FXXU4CSED/J730FXXU4CSF1
Board Platform: EXYNOS5
Modem Platform: SHANNON315
Serial Number: RF8K504VYSV
Imei: 350055352431456
Unique Number: CBJ00C5EF524B35
Connections: AT,MTP
Battery Status: 4.09V (76%)
Network Type: GSM
SIM Status: LOADED
Multisim Config: SS
Knox Version: v30
Warranty Bit: 0
Security Patch: 2019-05-01
Data Encryption State: unencrypted
Preparing...
Checking current patchcert.
Checking modem.
Checking root.
The phone is rooted by: 19.3:MAGISKSU
Checking boot image. Be patient! Do NOT disconnect the phone!
The knox is still valid. Because of the boot patch the warranty will void.
Writing boot image.
Restarting phone.
Waiting for ADB connection. Be patient! Do NOT disconnect the phone!
Reading data...
Checking modem version.
Downloading modem image. Be patient! Do NOT disconnect the phone!
Checking downloaded image.
Decompressing modem image.
Backing up actual modem. Be patient! Do NOT disconnect the phone!
Flashing modem image.
Switching to download mode.
Waiting for download mode.
Connecting.
SBL Info: Model: SM-J730F, Region: EUR, Provider: OPEN, PDA: J730FXXU4CSF1
Reading PIT from phone.
Flashing modem.bin
Restarting phone.
Restarting phone.
Reading data. Be patient! Do NOT disconnect the phone!
Patching certificate...
The operation is in progress. Be patient! Do NOT disconnect the phone!
After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds.
You can check the status of the imei using: *#0011#
The patchcert can be removed by repeating the process.
If a new firmware is used, the patchcert process must be repeated.
Succeeded.
Successfully finished.
Finished at local time: [08.24.19 10:30:12]
WorkID: 70774218
Old 08-26-2019, 17:03   #2 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 23,706
reply
Dear User,
In this case please do the following two methods:
1. reflash the device with the STOCK firmware and then run the IMEI REPAIR and the PATCH CERT service again. Then restart the device 3-4 times and wait at least 5 mins between each reboot.
2. Use the WRITE CERT service and then use the PATCH CERT. Then reboot the device 3-4 times.
Best Regards
Chimera Team
Model: SM-J730F
Sales Code: XEO
Product Code: XEO
Connections: AT,MTP
Network Type: GSM
SIM Status: LOADED
Multisim Config: SS
Knox Version: v30
Warranty Bit: 0
Preparing...
Checking modem.
Checking root.
Writing boot image.
Restarting phone.
Reading data...
Connecting.
Flashing modem.bin
Restarting phone.
Restarting phone.
Succeeded.
WorkID: 70774218
Old 08-26-2019, 23:46   #3 (permalink)
Member: 2521913
Thanks Meter: 251
Originally Posted by Chimera Tool View Post
Dear User,
Best Regards
Chimera Team
Just flash phone again and chenge root method I face this problem before try eft root or super su no magisk
Old 08-26-2019, 23:48   #4 (permalink)
Member: 2521913
Thanks Meter: 251
Or change firemwere................. It's hard but it will work
Page generated in 0.19271 seconds with 8 queries
