04-29-2020, 07:38 | #1 (permalink) |
Crazy Poster Join Date: Apr 2017 Location: PAKISTAN Age: 27
Member: 2711935 Status: Offline Sonork: no Thanks Meter: 11 | Sm-n960f u5 patch cert done Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N960F Sales Code: XME Country Code: MALAYSIA Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Feb 14 14:05:01 KST 2020 PDA Version: N960FXXS5DTB5 [february 2020, rev5] Phone Version: N960FXXS5DTB5 [february 2020, rev5] CSC Version: N960FOXM5DTB5 [february 2020, rev5] Product Code: XME HIDSw Version: N960FXXS5DTB5/N960FOXM5DTB5/N960FXXS5DTB5/N960FXXS5DTB5 Board Platform: UNIVERSAL9810 Modem Platform: SHANNON360 Serial Number: R58KA4QH23Z Imei: 356734098660412 Unique Number: CE071827E006ED2D217E Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-02-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [04.29.20 11:19:54] WorkID: 94139234 |
The Following User Says Thank You to amirshahzad07 For This Useful Post: |
05-03-2020, 14:31 | #5 (permalink) | |
Member: 2711935 Status: Offline Sonork: no Thanks Meter: 11 | Quote:
if your phone restart in (Checking root access.) or you have error unable to patch cert make sure you need to try difrent root mathod patch cert only work in only 1 condition when your phone reboot after complete patch not in checking root step | |
05-03-2020, 17:01 | #6 (permalink) | |
No Life Poster Join Date: May 2016 Location: IR
Member: 2575029 Status: Offline Thanks Meter: 122 | Quote:
root with magisk. step2 for check root phone reboot and chimera show patch cert done....but not done and cannot patch chimera software is bug. i 3month ago m205f u3 os10 patch cert done.but now check patch cert error. http://forum.gsmhosting.com/vbb/f898...-done-2785775/ | |
