07-02-2018, 18:59 | #1 (permalink) |
Banned Join Date: Mar 2011
Member: 1539068 Status: Offline Thanks Meter: 74 | Sony G3311 Xeria L1 phone gets stuck at mtk driver step..! Chimera Mobile Phone Utility version: 17.96.1422 @ 2018-07-02 Printing phone history Direct unlock 02/07/2018 15:57:35 [Get info] Connecting... Searching for Manufacture port... Couldn't connect to the phone. Please try the following: Try reconnecting the USB cable Please power off your phone, then insert USB cable while the device is still powered off. Check MTK drivers, and re-install them if necessary. Check Windows device manager. A new serial COM-port should appear associated to the phone at this stage. The procedure has been cancelled. Finished at local time: [07.02.18 18:59:06] WorkID: 40163391 |
07-03-2018, 14:35 | #4 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,767 | reply Hi, first of all sorry for the inconveniences. Device added with beta status previously, because our developer team working on the model continuously. At the moment we removed from the supported models list and it will be added again when we will have an 100% working solution for the exact device. Thank you for your patience. Best regards Nicole Quote:
05-23-2019, 16:03 | #6 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,767 | reply Hi, it is not yet supported. You are able to check our supported models here: https://chimeratool.com/en/models Best regards Nicole |
12-16-2021, 13:18 | #7 (permalink) | |
No Life Poster Join Date: Apr 2014 Location: istanbul
Member: 2171555 Status: Offline Thanks Meter: 129 | Quote:
12-16-2021, 14:10 | #10 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,767 | reply Dear User, The Chimera tool provides you a detailed instructions for it during the process. If that is not workable for you, please reinstall the chimera tool drivers , also use another USB Port and Cable for the connection. Make sure that every running background tool and software is closed + install the following driver as well: https://github.com/daynix/UsbDk/releases/tag/v1.00-22 Best regards Sab Chimera Team |
