09-07-2018, 17:33 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Caribbean
Member: 237911 Status: Offline Thanks Meter: 632 | [Suggestion] Pop Up adjustment This is the third time I did encountered this problem with chimera, If the phone has max number of wrong code attempt you need the code behind the pop up, sad to say there is no way to move the pop up, if you press "OK" button it will restart automatically, we save all the data of unlocking in our system, just in case if the client updated their phone and it gets lock, wherever they are in the world, they can call us back and give them the code, that is the reason why we need every line of code given by chimera. I hope you will adjust this in the next update. https://ibb.co/jAaDSz |
09-07-2018, 19:41 | #2 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,335 | Hi, sorry we always launch updates due to new improvements and bug fixes... so, in order to get your codes please, just check profile tab, then jobs and you can check your log including codes... Best Regards Chimeratool Team |
The Following 3 Users Say Thank You to Shensohau For This Useful Post: |
09-07-2018, 20:50 | #3 (permalink) | |
Member: 237911 Status: Offline Thanks Meter: 632 | Quote:
that is what im trying to find in the folder location, I though it is in the .txt file just like other boxes, thanks. | |
The Following User Says Thank You to eyestrain For This Useful Post: |
