Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 02-13-2019, 14:49   #1 (permalink)
Member: 2483507
Thanks Meter: 81
Exclamation want to know info about New patch Cert!!!
Hlw Chimera Team,
thanks for support latest patch cert, read/write cert option on latest samsung models.
I want to know is this option support latest security patch label and latest android version.
Because I want to buy it's today.
please explain.
BR.
Old 02-13-2019, 15:02   #2 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 2,849
Hi, answer is yes...
The Following User Says Thank You to Shensohau For This Useful Post:
Old 02-13-2019, 15:08   #3 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,738
Originally Posted by sany5491 View Post
Hlw Chimera Team,
please explain.
BR.
Patch certificate is it working on latest security android 8
Patch certificate need root.
If you want to write certifcate, read it or repair Imei, no need root and knox must be void to 0X0000.
The Following 2 Users Say Thank You to gcceleghg For This Useful Post:
Old 02-13-2019, 15:23   #4 (permalink)
Member: 2483507
Thanks Meter: 81
thank you brother.....
Old 02-13-2019, 15:24   #5 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,738
Notes:
  • Cert Read, Cert Write and Imei Repair Processes Work Without Root
  • Patch Cert Process Needs Root
  • *KNOX must be 0
Old 02-13-2019, 15:25   #6 (permalink)
Member: 2613252
Thanks Meter: 1,597
Hello GCCELEGHG, I wanted to know the information on Cert patch of Chimera tool.
The IMEI patch and repair is only supported for Android 8 or you can do it even for Android 9?
And if you do the factory reset or the firmware update the CERT patch disappears and the network does not work?
Old 02-13-2019, 15:47   #7 (permalink)
agentot's Avatar
Member: 107027
Thanks Meter: 200
Added Cert Read/Write, Imei Repair For Exynos Models - First in the World
Samsung Galaxy A8 (SM-A530F, SM-A530N, SM-A530W,SM-A530N)
Samsung Galaxy A8+ (SM-A750F, SM-A750FN, SM-A750G, SM-A750GN, SM-A750N, SM-A730F)
Samsung Galaxy S9 (SM-G960F, SM-G960N, SM-G965F, SM-G965N)
Samsung Galaxy Note 9 (SM-N960F, SM-N960N)
Samsung Galaxy J7 Duo (SM-J720F, SM-J720M)
Samsung Galaxy J2 Core (SM-J260M)
seems s9 don't have patch network! so imei repair on g960f doesn't work?
br
ss
Old 02-13-2019, 16:05   #8 (permalink)
m&s
m&s's Avatar
Member: 1168673
Sonork: 100.1638333
Thanks Meter: 169
Phone Version: J600GDXU3ARH3 [august 2018, rev3]
CSC Version: J600GOWA3ARH4 [august 2018, rev4]
Product Code: PET
HIDSw Version: J600GUBU3ARH4/J600GOWA3ARH4/J600GDXU3ARH3/J600GUBU3ARH4
Board Platform: EXYNOS5
Modem Platform: SHANNON315
Serial Number: R28KB2ZK4AY
Imei: 352821102582551
Unique Number: CBJ005705470BA5
Connections: AT,MTP
Battery Status: 3.83V (43%)
Network Type: GSM
SIM Status: ABSENT
Multisim Config: SS
Knox Version: v30
Warranty Bit: 0
Security Patch: 2018-08-01
Data Encryption State: encrypted
Preparing...
Checking current patchcert.
Checking modem.
Checking root.
We cannot root this phone. Try to root manually.
Finished at local time: [02.13.19 10:57:41]
WorkID: 52470740
Old 02-13-2019, 16:09   #9 (permalink)
GeorgeEcuador's Avatar
Member: 904826
Sonork: 100.1603284 GeorgeEcuador
Thanks Meter: 556
j400m imei 00000000000000000000
Old 02-13-2019, 16:12   #10 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 15,800
reply
Hi,
could you write us some more info about your case or write use exact question?
Thank you in advance!
Best regards:
Nicole
The Following User Says Thank You to Chimera Tool For This Useful Post:
Old 02-13-2019, 16:12   #11 (permalink)
Member: 1787203
reply
Hi,
Thank you for your report, please try to root manually your device and start the process again.
Best regards:
Nicole
Product Code: PET
Connections: AT,MTP
Network Type: GSM
SIM Status: ABSENT
Multisim Config: SS
Knox Version: v30
Warranty Bit: 0
Preparing...
Checking modem.
Checking root.
WorkID: 52470740
Old 02-16-2019, 07:28   #12 (permalink)
Member: 199814
Thanks Meter: 1,941
G960f repair imei did but there is no option to patch cert so it will not worki? its not showing service
Old 02-18-2019, 09:22   #13 (permalink)
Member: 1787203
reply
Hi,
Patch cert not supported on your device at the moment.
"Added Cert Read/Write, Imei Repair For Exynos Models - First in the World
  • Samsung Galaxy A8 (SM-A530F, SM-A530N, SM-A530W,SM-A530N)
  • Samsung Galaxy A8+ (SM-A750F, SM-A750FN, SM-A750G, SM-A750GN, SM-A750N, SM-A730F)
  • Samsung Galaxy S9 (SM-G960F, SM-G960N, SM-G965F, SM-G965N)
  • Samsung Galaxy Note 9 (SM-N960F, SM-N960N)
  • Samsung Galaxy J7 Duo (SM-J720F, SM-J720M)
  • Samsung Galaxy J2 Core (SM-J260M)"
Used you the original imei of the device when you started the imei repair process?
Best regards
Nicole
Old 05-14-2019, 08:42   #14 (permalink)
Member: 2394246
Sonork: Fddgg
n960f cert write error
chimera tool
knox warranty void 1(0x0500)
how fix it???
help me thx
Old 05-14-2019, 10:22   #15 (permalink)
Member: 1787203
reply
Hi,
could you write me the work id of the problematic write cert process please?
Best regards
Nicole
Originally Posted by supun8808 View Post
chimera tool
how fix it???
help me thx
Page generated in 0.43243 seconds with 7 queries
