Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GPGeMMC
Old 03-23-2016, 00:42   #1 (permalink)
Member: 667857
Thanks Meter: 33
Box not connect erro erro erro
always i have this problem
Old 03-24-2016, 09:16   #2 (permalink)
Member: 2385015
Thanks Meter: 876
Hello,
Please Download latest version and use it.
Br,
GPGTeam
Old 03-24-2016, 10:34   #3 (permalink)
Member: 667857
Thanks Meter: 33
WITH LAST version 1.35
Old 03-25-2016, 06:05   #4 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,358
Edit your registry and remove "GPG EMMC" from it.
For this
1. go to "run"
2. type "regedit" and hit ENTER button
3. now go "HEY_CURRENT USER"
4. then, go "software" expending tree view
5. now, check for "GPG" and expend it.
6. Now, you will see "GPGeMMC"
7. Right click on it (right click GPGeMMC) and choose "Delete"
8. Confirm to it click "Yes"
9. Now, reinstall latest software from the support
GPG EMMC Support Site
10. Done.
11. Run "GPGeMMC" latest software while internet is working fine.
12. while your software get server, then, it will send license to this device.
13. Voila!! Now, you are ready to do operations.
If you still get trouble, then, post here logs of GPG EMMC device. Before this, you have to consider some facts too:
Did you try with other PC? with Different Windows? Is your internet working fine ? Some internet provides might block our server, so also ask them about this. Never use 64 bit windows.
Well, we are here for customer care. So, keep in touch.
Good Luck !!!
Dipendra Pathak
Old 03-29-2016, 02:38   #5 (permalink)
Member: 667857
Thanks Meter: 33
I use 32 bit windows7 & XP
MY SPEED internet 4 MEGA
I USE 2 PC with new windows
Run "GPGeMMC" latest software 1.35
Box not connect
Old 03-29-2016, 02:50   #6 (permalink)
Member: 667857
Thanks Meter: 33
http://img.gsm-7dev.com/images/nip5bpgay4ne5gjc738.jpg
Old 03-29-2016, 04:09   #7 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,358
bro, post your log here so that i can check and confirm from our server too.
Normally you find log fine to the following location:
C:\Program Files\GPG EMEC\log
Open it, copy its contain and paste over here.
Dipendra Pathak
Old 03-30-2016, 07:12   #8 (permalink)
Member: 667857
Thanks Meter: 33
29/03/2016 02:59:26 AM >>Connecting...
29/03/2016 02:59:28 AM >>SN:00000100172
29/03/2016 02:59:28 AM >>Get License data...
29/03/2016 02:59:28 AM >>Connect server...
29/03/2016 02:59:34 AM >>Cannot connect to server, check whether the network is available, or use a proxy server.
29/03/2016 03:00:31 AM >>Connecting...
29/03/2016 03:00:32 AM >>SN:00000100172
29/03/2016 03:00:32 AM >>Get License data...
29/03/2016 03:00:32 AM >>Connect server...
29/03/2016 03:00:37 AM >>Cannot connect to server, check whether the network is available, or use a proxy server.
29/03/2016 03:00:52 AM >>Connecting...
29/03/2016 03:00:53 AM >>SN:00000100172
29/03/2016 03:00:54 AM >>Get License data...
29/03/2016 03:00:54 AM >>Connect server...
29/03/2016 03:00:59 AM >>Cannot connect to server, check whether the network is available, or use a proxy server.
29/03/2016 03:01:10 AM >>Connecting...
29/03/2016 03:01:11 AM >>SN:00000100172
29/03/2016 03:01:12 AM >>Get License data...
29/03/2016 03:01:12 AM >>Connect server...
29/03/2016 03:01:17 AM >>Cannot connect to server, check whether the network is available, or use a proxy server.
29/03/2016 03:01:41 AM >>Connecting...
29/03/2016 03:01:42 AM >>SN:00000100172
29/03/2016 03:01:42 AM >>Get License data...
29/03/2016 03:01:42 AM >>Connect server...
29/03/2016 03:01:47 AM >>Cannot connect to server, check whether the network is available, or use a proxy server.
29/03/2016 03:02:07 AM >>Connecting...
29/03/2016 03:02:08 AM >>SN:00000100172
29/03/2016 03:02:08 AM >>Get License data...
29/03/2016 03:02:08 AM >>Connect server...
29/03/2016 03:02:13 AM >>Cannot connect to server, check whether the network is available, or use a proxy server.
29/03/2016 03:09:04 AM >>Connecting...
29/03/2016 03:09:05 AM >>SN:00000100172
29/03/2016 03:09:05 AM >>Get License data...
29/03/2016 03:09:05 AM >>Connect server...
29/03/2016 03:09:10 AM >>Cannot connect to server, check whether the network is available, or use a proxy server.
29/03/2016 03:12:30 AM >>Connecting...
29/03/2016 03:12:32 AM >>SN:00000100172
29/03/2016 03:12:32 AM >>Get License data...
29/03/2016 03:12:32 AM >>Connect server...
29/03/2016 03:12:37 AM >>Cannot connect to server, check whether the network is available, or use a proxy server.
29/03/2016 03:12:52 AM >>Connecting...
29/03/2016 03:12:54 AM >>SN:00000100172
29/03/2016 03:12:54 AM >>Get License data...
29/03/2016 03:12:54 AM >>Connect server...
29/03/2016 03:12:59 AM >>Cannot connect to server, check whether the network is available, or use a proxy server.
29/03/2016 03:44:13 AM >>Connecting...
29/03/2016 03:44:14 AM >>SN:00000100172
29/03/2016 03:44:15 AM >>Get License data...
29/03/2016 03:44:15 AM >>Connect server...
29/03/2016 03:44:20 AM >>Cannot connect to server, check whether the network is available, or use a proxy server.
Old 04-05-2016, 07:29   #9 (permalink)
Member: 2385015
Thanks Meter: 876
iam waittttttttttttttttttttttttttttttttttttttttttttttt ttttttttttttttttttttttttt
Hello,
Please use latest GPGeMMC version 1.35 here's Downloading Link.
Please Download from here Index of ./GPGeMMC/Setups/
Br,
GPGTeam
Old 04-09-2016, 05:48   #10 (permalink)
skyulock's Avatar
Member: 757064
Thanks Meter: 253
Originally Posted by Natashah View Post
Hello,
Br,
GPGTeam
bro sorry no more support again..........
Old 04-09-2016, 09:38   #11 (permalink)
Member: 2385015
Thanks Meter: 876
Hello Sir,
What's your problem?
Old 04-11-2016, 05:18   #12 (permalink)
Member: 667857
Thanks Meter: 33
Box not connect erro i used last v 1.35
Old 04-11-2016, 10:18   #13 (permalink)
Member: 2385015
Thanks Meter: 876
Hello,
Please Check Drivers and make sure you are using 32Bit windows.
Br,
GPGTeam
Old 04-13-2016, 21:01   #14 (permalink)
Member: 667857
Thanks Meter: 33
Hello,
Br,
GPGTeam
plz read my problem i do ever thing need a soultion
iam used 3 pc 3 win 32 bit used last v 1.35 with new win oky
iam not uesd my box only 2 phone and stoped
Old 04-14-2016, 12:36   #15 (permalink)
Member: 2385015
Thanks Meter: 876
Hello,
If drivers are ok then please check hardware issue.
Br,
GPGTeam
Page generated in 0.40219 seconds with 8 queries
